89 iroc dash/steering colum
Old Sep 15, 2011 | 08:58 PM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
My iroc has a cracked dash,Yes the dash pad also,The dash itself is the biggy.Also there is a piece at the place where the steering wheel meets the dash thats missing.This dash isn't like a 89 rs I looked at for parts.Even my arm rest are more heavy made.Instead of the bottom of the dash going all the way accross as one padded piece,it's just a plastic piece.I feel like this is a special interior.Can these only be found in iroc's?
Old Sep 16, 2011 | 05:07 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Re: 89 iroc dash/steering colum
pictures?
Old Sep 16, 2011 | 06:55 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
yea, id like to see pics as well, what youre describing doesnt sound like any 3rd gen dash...
Old Sep 17, 2011 | 11:53 AM
Bobby Suth's Avatar
Axle/Gears: 273?277
See what these can do to help.
Attached Thumbnails 89 iroc dash/steering colum-camaro-89-dash-007.jpg   89 iroc dash/steering colum-camaro-89-dash-002.jpg   89 iroc dash/steering colum-camaro-89-dash-001.jpg
Old Sep 17, 2011 | 11:56 AM
Bobby Suth's Avatar
Axle/Gears: 273?277
more
Attached Thumbnails 89 iroc dash/steering colum-camaro-89-dash-002.jpg   89 iroc dash/steering colum-camaro-89-dash-003.jpg   89 iroc dash/steering colum-camaro-89-dash-004.jpg
Old Sep 17, 2011 | 12:03 PM
travis401's Avatar
Car: 91 Camaro RS
ah ok, yea thats a stock dash, it just looks like someone has screwed up your sterring column or took the cover peices off. you should be able to score either the missing pieces, or a whole column in a jy.
im curious as to what the big black box on the bottom of the dash is...
Old Sep 17, 2011 | 12:04 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
not a duplicate
Attached Thumbnails 89 iroc dash/steering colum-camaro-89-dash-008.jpg   89 iroc dash/steering colum-camaro-89-dash-006.jpg   89 iroc dash/steering colum-camaro-89-dash-005.jpg
Old Sep 17, 2011 | 12:07 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
don't know what that is.Maybe some kind of security stuff.I don't have a key for it and havnt tryed to trace the wires yet.Where you say I can get the parts from?what about under the dash? shouldn't there be somthing over thewires
Old Sep 17, 2011 | 12:10 PM
travis401's Avatar
Car: 91 Camaro RS
junk yard. does the car start with the normal key? id trace the wires out and see what that is, it looks like it was an horrible idea whatever it is.
Old Sep 17, 2011 | 12:24 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
The standard vats key starts the engine.this box has a totaly different type of key.Our jy don't have any 3rd gens in them.I've got a recked(rearended)90firebird.but it dosnt look the same.There has got to be somthing that gose over these wires.The black box is in the way.
Old Sep 17, 2011 | 01:23 PM
Kevin84Z28's Avatar
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
Yes, you are missing the under dash panel that covers all of the wires. It connects above the pedals and comes up to the bottom of the dash, just under the steering column.
Old Sep 17, 2011 | 01:56 PM
travis401's Avatar
Car: 91 Camaro RS
firebirds IIRC, have a totally different dash than the camaros
Old Sep 17, 2011 | 06:04 PM
gotabekidding's Avatar
Car: 91 & 88 GTA, 89 Formy, 89 bird
Engine: 3 - 350 TPI, 305 TBI
Transmission: All 700R4's
Axle/Gears: unknown
that switch is either to an aftermaket alarm or a hood lock system.
Old Sep 17, 2011 | 07:05 PM
Kevin84Z28's Avatar
That's correct, they look similar but in no way do the Firebird/Camaro dash pads interchange. I bet a lot of people get dissapointed in that since I see a lot of dash pads of Ebay advertised as Firebird-Camaro dash pad...
Old Sep 18, 2011 | 05:25 PM
Axle/Gears: unknown
The firebird has a cover for the speaker and no knotch for the center air conditioning vents.
I think that the side defrost vents are a different size as well, could be wrong on that.
The camaro dash pad has the speaker holes molded in the pad (cracks love to start there)
A camaro dashpad will fit in a firebird, but a firebird dashpad will not fit in a camaro.
Old Sep 18, 2011 | 11:26 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
well thats not fair,I see alot more good bird pads. Back to the under panel cover,I've got a paded piece that came out of an 89 RS.Is that supposed to cover over the plastic stuff all the way to the bottom of the stering colum?I can take that black box loose and put it up for now.The 90 RS looked to be the same as the 89 RS.Sence my 89 iroc never had one when I got it I dont know how it is supposed to look.
Old Sep 20, 2011 | 12:54 AM
Bobby Suth's Avatar
Axle/Gears: 273?277
OK,I've compaired the under colume area in all my cars.The 90 rs and 90 bird have the same look as the piece that I got out of what was supposed to be a 89rs.Maybe that car was a 90.Because the outside would have looked like the 89 but the interior would have been different.Oh and the 86 bird looks alot like the iroc.But it is different.
angel2794
Sep 8, 2015 06:22 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
mustangman65_79
Aug 23, 2015 02:00 AM
g.l.mos
Aug 22, 2015 12:02 AM
mustangman65_79
Aug 11, 2015 03:17 PM
