88 TRANS AM GTA
Car: 1970 Plymouth Hemi Cuda
Engine: 426 Hemi
Transmission: A833 4 Speed
Axle/Gears: Dana 60
88 TRANS AM GTA
I have an 88 Trans Am GTA, and i would like to change out the cracked dash pad for a new one.
Am i right in thinking that the only thing that holds the dash pad on, is the few screws in the wind shield vent and the hex head bolts that run along the front of the dash, underneath it???
Or is there a whole host of hidden screws and bolts under the dash and at the back of the dash that you cant even see of feel but are still expected to get out?
I'll also use this as an excuse to change out the front speakers for some modern ones.....
Car: 1988 IROC Z
Engine: 5.7 litre
Axle/Gears: 3.27 Posi with 4 wheel disc brakes
Re: 88 TRANS AM GTA
There arent any hidden screws or bolts. Remove the screws in the defrost section and the hex head tols under the front of the dash and the dash will come out.
Engine: 426 Hemi
Axle/Gears: Dana 60
Re: 88 TRANS AM GTA
Awesome thank you. That has to be the easiest job ever. Not like some of the dashes i've fooled with.
I'm guessing once the dash pad is off, the speakers are exposed and real easy to get out?
The_Phoenix
Feb 4, 2016 07:10 AM
