Changing power seats to manual base
Old Sep 25, 2011 | 09:46 AM
peterc005's Avatar
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
I have a 1988 IROC with an electric Left Hand seat.
The car has been converted to Right Hand Drive.
If I get the base from a Left Hand manual seat, can I install it on my seat?
Alternatively, could I move the seat wiring over to the Right Hand side and swap the electric/manual seat bases so that the Right Hand (drivers side) has power seats?
Old Sep 25, 2011 | 02:39 PM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
Re: Changing power seats to manual base
The wiring can be spliced and extended to reach the passenger side, or, if you check the search engine here, I believe there may be posts on how to wire both seats to be power.
You can take the existing left seat track and put it on your right seat as well, however, although the wires are long enough to reach either side of the seat, you will have to make some modifications to put the seat controls on the right side of the right seat.
Old Sep 25, 2011 | 07:38 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
I had a look at this a few years ago when I had the seats out. From memory, it looked like the bases should swap left-right, but the controls and plastics are handed and would take quite a bit of fab work. Still kind of annoyed GM was too cheap to put in 2 power seats.
jaridjohn
Jul 8, 2024 03:49 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
kyleb24
Aug 15, 2015 08:24 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
