HELP - Seat tilt is broken
Old Nov 8, 2011 | 04:20 PM
Mike92Firebird's Avatar
Car: 89 GTA
Engine: 5.7 TPI L98
Transmission: 700R4 w/ Stage 2 shift kit & stall
I've got an 89 GTA with the OEM seats, black cloth with the power lumbar. Well anyways, I was accelerating from a stop yesterday and I felt myself literally tilt into my back seat. The lever directly underneath the seat that controls the tilt mechanism appears to be broken, but only on the left hand side of the seat. Meaning that the entire seat rocks forward and backwards, but mostly only on the left side. Anyone here a seat expert that can give me some idea how to fix this? It has made my favorite car extremly uncomforatble to drive
Old Nov 8, 2011 | 06:09 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
Re: HELP - Seat tilt is broken
I'm not sure about this "... left side", but here's what I can add to the issue.
Third gen seats are constructed with the latch/tilt mechanism, on the
outside, i.e toward the door (driver seat -> left side, pass ->
right side). The inside mounting is a simple pivot bolt, so all control
is in the latch/tilt mechanism.
The pic is (I believe) a pass latch, with the cutaway intended to illustrate
the tilt-lock feature, which was the subject of another thread.
Long story short is that you probably need another driver-side latch.
If you don't have any good salvage lots close, try posting a WTB in
the classifieds.
OR...
Is your driver side seat mount like the second pic?
If that's the issue, I may be able to help, if you can get some good pics
of your's.
Good luck,
kk
Attached Thumbnails HELP - Seat tilt is broken-seat_hinge_01.jpg   HELP - Seat tilt is broken-seat-tilt-2.jpg
Old Nov 8, 2011 | 06:21 PM
Car: 89 GTA
Engine: 5.7 TPI L98
I understand what you're talking about but I might've worded it incorrectly. The problem with my seat is Not the tilt for your back, but the lever directly under your seat which adjusts the angle towards the wheel your seat is at. By "left side" I meant the part you literally sit your butt on, near the front left, seems to be unlatched and tilts.
Old Nov 8, 2011 | 07:39 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
The seat " rocks "?
Check all the floor bolts. 4 per seat.
That's if I understand the question.
Old Nov 8, 2011 | 07:52 PM
Car: '87 Camaro
Well, maybe not what I thought! Sorry!!
Old Nov 8, 2011 | 08:30 PM
Drew's Avatar
It sounds like you've got the manual 4 way seat track. If you pull the seat and look, I bet you'll find one of the rivets or pins sheered off, or worn down. It's a really simple mechanism, just pull it out and give it a look.
Old Nov 8, 2011 | 10:57 PM
Car: 89 GTA
Engine: 5.7 TPI L98
I'll have to give it a shot. Just hope it's not a big deal to pull the seat. Does it just take a normal size ratchet or is it a special type of bolt?
Old Nov 8, 2011 | 11:19 PM
Drew's Avatar
It takes a couple minutes with a 13mm gearwrench to get the seat out, one nut at each corner of the seat, then lift it out.
Old Nov 8, 2011 | 11:42 PM
Car: 89 GTA
Engine: 5.7 TPI L98
Wonder what type of treasures I'll find under a 22 year old seat :O
Hopefully this is an easy fix.
Veaceonee
Sep 29, 2016 08:15 PM
PurelyPMD
May 5, 2016 04:57 PM
skeltor
Feb 2, 2016 10:37 AM
ctoledo0834
Sep 18, 2015 04:16 PM
m00n420
Sep 11, 2015 02:39 PM
