92 firebird cupholders, need help
Car: 1992 Firebird convertible
Engine: 5.0 tbi
Axle/Gears: stock, slow and steady 2.73's
I have a 1992 firebird and the top screw hole on both cup holders has broken off on the back side of the holders. So basically the top screws on both have nothing to hold onto. Any suggestions on how to fix it? Or if any for sale tell me, I need the tan ones
Re: 92 firebird cupholders, need help
Try a good 30-minute or longer epoxy... JBWeld for example. The longer it takes to set, generally the stronger the resulting joint will be.
Engine: 4++,350 & 305 CIs
I have had luck melting them together with a soldering iron.
dont breath the fumes
Car: 1990 firebird formula 5.0
Engine: 305 tbi
Axle/Gears: 2:73
Jb weld works great. But make sure not to torque screws down too much. even when set up completely I've cracked it and had to start all over
I used crazy glue and it popped right off
Second attempt with 2 part plastic epoxy building it up layer after layer. Still holding strong 3 years and many big feet later
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
