Aftermarket Headliner install question
Old Nov 12, 2011 | 02:19 PM
Fronzizzle's Avatar
Car: 1985 IROC-Z
Engine: 383
The headliner in my car was destroyed, so I purchased an ABS plastic aftermarket one. Getting ready to install and I have a question.
The shoulder belt is mounted on ceiling and comes through the headliner. If you look at the headliner, there is a spot that was removed from the plastic where the seat belt sits. There is also a cut in the plastic that goes from this cut out to the edge of the headliner. I assume that I'm supposed to cut the fabric in this area and then slide the seat belt into place, right? Seems the only way to get it into place, but when done I'm going to have a slit in the headliner and I really don't see anyway to fix it. Am I missing something?
Old Nov 12, 2011 | 02:39 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
Re: Aftermarket Headliner install question
there should be a plastic part that slides up into place to cover that slit. thats how the factory ones install as well.
Old Nov 12, 2011 | 02:53 PM
Fronzizzle's Avatar
Car: 1985 IROC-Z
Engine: 383
Huh. Okay. Not sure I have that...changed the interior color of my car, so I bought some used seat belts. I will have to see if they are pieces are there, or on my old ones. Thanks.
Old Nov 12, 2011 | 02:57 PM
Pillsbry10's Avatar
it should be on the seatbelt...it will slide up into place and clip into the seatbelt assembly.
Old Nov 15, 2011 | 06:06 AM
Fronzizzle's Avatar
Car: 1985 IROC-Z
Engine: 383
The seatbelts I purchased do not have these pieces; the original driver side one doesn't either, but the passenger does.
I have found numerous pieces for sale on ebay, but how do I get them on after? I assume that I'll have to carefully cut them, slide them over the belt and then glue them back together or something?
Old Nov 15, 2011 | 09:17 AM
Steven6282's Avatar
Car: 1986 Z28 Camaro
Engine: 350 with .440" lopey cam
Transmission: 6spd T56
Axle/Gears: Detroit Truetrac with 3.73 gears
I've been wondering this same thing. I recently had to change my headliner again, and well 26 year old plastic is brittle and I broke the last two tabs off my passenger side one. So I'm going to have to replace it but don't see anyway to get a new one on the seatbelt without unstitching the belt, which is not something I'm willing to do.
To get my old one off I used a dremel with a thin cut blade, and I suppose if I bought new ones to put on I could put them on the same way and it wouldn't look horrible. But I'm curious to the proper way to do it.
Old Nov 15, 2011 | 12:12 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
There are after market pieces that have a slit made into them.
I dont recall the colors available or where Isaw them..
I do recall they are around $35-$40 EACH!!!
Try Thirdgenranch, Hawks, 1AAuto, Classic industries, or ebay.
You can cut your own slit, but you have to be careful you don't break the mounting tabs.
Old Nov 16, 2011 | 11:45 AM
Fronzizzle's Avatar
Car: 1985 IROC-Z
Engine: 383
I bought a pair of black ones off of ebay, they were like $30 total. No slits. I'm going to practice on the one that's still mounted on my old seat belt first to see what the best way to cut it is. I'm guessing band saw but I don't know for sure.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Golfvette
Aug 24, 2015 06:35 PM
redmaroz
Aug 16, 2015 11:40 PM
TheJoeY88
Aug 13, 2015 06:51 PM
