4thgen rear view mirror question...
Old Nov 20, 2011 | 12:38 AM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
I'm going run a 4thgen rear view mirror i have ran wires for the rear view mirror courtesy lights and everything is ready to go... but i have a wider size attachment on the windshield where my OEM 3rdgen mirror mounted to the glass, the 4thgen mirror mount isn't as wide and can be detached by unbolting the torques bit in the center of the mount where as the 3rdgen one is fixed and can not be unbolt... So my question is where can i get the 3rdgen style mount that i can bolt on the 4thgen post? i don't really want to take the attaching peace off the windshield id rather just swap mounts.
here is a pic to give you some insight on what im talking about
(3rdgen on your left, 4thgen on your right)
Old Nov 20, 2011 | 02:16 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: 4thgen rear view mirror question...
The mounts bolt to the circuit boards.Open the mirrors, remove the bolt, then just swap the mounts.Crazy glue the housings back together.
Old Nov 20, 2011 | 02:27 AM
FueledSoul's Avatar
no thanks...
Old Nov 24, 2011 | 09:45 PM
FueledSoul's Avatar
anyone else know? if not i think i can fab something up but if i can just swap the peaces then sweet...
Old Nov 25, 2011 | 09:56 AM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
its easy to swap the mounts on the glass, theyre just glued on. you can get the glue to put the 4th gen button on at most auto parts stores.
Old Nov 25, 2011 | 02:46 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
I've bumped mine a number of times hard enough to knock the button loose from the windshield. The rear view mirror cement available at the auto parts stores is some pretty good stuff and sets up pretty fast, but get it right the first time because it's a single use package.
Also, there's a small mark on the windshield to aid in positioning the mirror's mounting button.
Old Nov 25, 2011 | 03:01 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Mark it with tape before taking the old one off. This is super simple.
Old Nov 25, 2011 | 03:06 PM
FueledSoul's Avatar
So its easier to remove the mount from the windshield? iv never dealt with the the mounts on the glass, how hard is that to take off and what methods do you use, i would assume a source of heat and a razor blade ?
Old Nov 25, 2011 | 03:21 PM
Al Hasse's Avatar
I've never actually removed the mount on purpose. I've had it come off while trying to move an object across the front seat instead of loading it from the passenger side, and bumping the mirror with it In this case, marking the spot with tape wasn't an option, just happened to notice a very small mark on the windshield where the mount goes.
Old Nov 25, 2011 | 06:22 PM
travis401's Avatar
Car: 91 Camaro RS
ive never pulled one off on purpose either, i gotta reglue the one back in the camaro, i knocked it off working around the interior.
i guess you can try to attach the 3rd gen mirror and rock it back and forth ans see if it pops it off. as long as you dont really pry on it i dont see any harm being done.
Old Nov 25, 2011 | 09:15 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
can you glue the new button to the old button?
Old Nov 25, 2011 | 09:37 PM
travis401's Avatar
Car: 91 Camaro RS
theoretically yes, but the mirror will stick that much further out from the windshield, and would look ghetto as hell. and if ive gathered anything from the OP posts, hes the last person to do something like that.
Old Nov 25, 2011 | 09:53 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
i wouldnt just try to pry it it will crack your windshield. use a heat gun then try to remove it.
Old Nov 25, 2011 | 10:19 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Originally Posted by Pillsbry10
...use a heat gun then try to remove it.
NO!!!!!
I tried that once & guess what? The Safety Film, between the layers of glass popped & gave me a real bad starburst pattern along with a bunch of bubbles.
DO NOT heat your glass with a heat gun, unless you want to totally destroy the glass.
Old Nov 25, 2011 | 10:33 PM
Pillsbry10's Avatar
lol if you left it on there long enough to do that then that was your bad....use a hair dryer then if you have no self control.
Old Nov 26, 2011 | 06:59 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Here's what my small town automotive glass shop recommended (and the method worked fine for me, though my heart was in my throat the whole time):
Hit the button evenly with a propane bottle torch for a few seconds, then using pliers, gently twist. The operation took several repetitions for the button to twist free. No ill effects.
JamesC
Old Nov 26, 2011 | 09:24 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
I see a broken windshield in someones future!
1992 Trans Am
May 10, 2023 07:19 PM
Street Lethal
Apr 30, 2019 12:14 PM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
89FormulaMan
Aug 10, 2015 10:01 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
