Got some new seats!
Old Dec 29, 2011 | 10:30 PM
Slayerx666's Avatar
Got some new seats!
65 bucks! And yes. They are mismatched. I do not care! Only took a couple of holes drilled.
I'm pretty happy over all. I can always have them recovered or dye them. I think I'll deal with them.
Old Dec 30, 2011 | 02:38 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Got some new seats!
not bad, id dye them to match since the fabric looks like its in good shape. how comfy are they?
Old Dec 30, 2011 | 02:41 PM
Slayerx666's Avatar
Not bad a little stiff. But they're brand new so I'm sure they'll get softer .
Old Dec 30, 2011 | 04:43 PM
travis401's Avatar
Car: 91 Camaro RS
you got brand new seats for $65, where?
Old Dec 30, 2011 | 05:03 PM
Slayerx666's Avatar
Craigslist!
Old Dec 30, 2011 | 05:06 PM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
vacuum your car!
just givin' you a hard time
Old Dec 30, 2011 | 05:19 PM
Slayerx666's Avatar
Lmao I'm still building it! It's not ready to be cleaned!
Old Dec 30, 2011 | 05:25 PM
travis401's Avatar
Car: 91 Camaro RS
pull the carpet and give it a good steam cleaning while youre at it.
Old Dec 30, 2011 | 05:50 PM
Slayerx666's Avatar
Yea it's pretty stained
Old Dec 30, 2011 | 06:32 PM
travis401's Avatar
Car: 91 Camaro RS
it be the perfect time to dye the carpet and seats with the same dye so they match.
Old Dec 31, 2011 | 03:44 AM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
looks good man
Old Jan 23, 2012 | 09:45 AM
Slayerx666's Avatar
Is Dying suede simple? I want to dye them both black, and I want to dye the carpet, which I'm sure I'll need a different dye than the seats?
Old Jan 23, 2012 | 09:56 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
You're gonna need to do something about the seatbelt hoop. If you dont get one it's gonna be really annoying and it'd be pretty unsafe in an accident too.
Old Jan 23, 2012 | 10:08 AM
Slayerx666's Avatar
I plan in putting in a 4 point cage, and harnesses.
Old Jan 23, 2012 | 11:38 AM
Car: 1992 Camaro RS
That solves that problem... but still, harnesses aren't street legal. So have a backup plan if you can in case the popos give you a hard time.
Old Jan 23, 2012 | 03:02 PM
DENALSKY's Avatar
Car: 1991 camaro z28
How did you get the seats bolted down? Did you use new mounts or rigged the old ones? Im in the middle of trying to get mine in, its pissing me off. I used a lathe to drill holes into the stock ones to mach the length only to find out its to short width wise. Im about to make a temp-let and make custom ones if i fail again.
Old Jan 31, 2012 | 01:44 AM
Slayerx666's Avatar
The front holes matched up to the rails, then I slid the sliders all the way up to drill holes for the rear. I got lucky and was able to get all four nuts on the floor on each seat.
Old Feb 1, 2012 | 02:42 AM
nickfrmtx89's Avatar
Car: 1992 Camaro RS
Engine: 305 5.0L TBI
some harnesses aren't legal. Scroth makes DOT approved harnesses. or if u have a scratch DOT tag u could have it sewn in on the back of one of the straps, lol.
Old Feb 1, 2012 | 08:12 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
even if they dont match, thats a heck of a deal and look good too. little dye should make it a steal.
Old Feb 2, 2012 | 12:55 AM
IROC#1's Avatar
Car: 1988 IROC Z
Engine: 5.7 litre
Axle/Gears: 3.27 Posi with 4 wheel disc brakes
Thats what I was thinking!! He should have dyed the carpet before installing the seats...If both the seats and carpet were dyed that interior wouldnt look half bad. Right now with mismatched seats and filthy carpet it looks like crap.
To the OP--you could have done this right in 1 day instead you cut corners and just installed the seats. If you really care about your car do it the right way!
Old Feb 2, 2012 | 01:03 AM
Slayerx666's Avatar
The car isn't even fully running yet. It's a project, and not on the road. I was making sure they fit is all. The carpet will be dyed and cleaned. Along with the seats. It will get done don't worry. I'm not one to cut corners.
Old Feb 2, 2012 | 01:55 AM
Slayerx666's Avatar
Where do I get carpet dye? I've never dyed a carpet.
MrPackstin
Oct 25, 2017 08:09 PM
GageBrand
Oct 22, 2015 02:30 PM
Briandrex
Oct 5, 2015 06:20 AM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
kitt23
Sep 26, 2015 07:48 PM
