Interior Rear View Mirror
Old Jan 14, 2012 | 11:24 PM
Mr. McGuire's Avatar
Car: 91 Camaro Z28
Engine: 305 V8 (5.0L) TPI
Ok, so I have a 91 Z28 and the other day when polishing the interior my elbow knocked the rear view mirror off. Instead of putting it back on again I decided that I should get the "reading" lights on it fixed first. I couldn't figure out how to get to the bulbs in the lights to replace them. If someone could help that would be greatly appreciated Also telling me the bulb size I would need for the lights will also be appreciated. THANK YOU!
Old Jan 15, 2012 | 08:28 PM
tavert91's Avatar
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
Re: Interior Rear View Mirror
If they are the same as the Pontiac's lamps, they just pop out in a downward direction (with the mirror in the normal position). Use a small, narrow blade screw driver and insert it between the left or right edge of each lens and the mirror frame. Be gentle and the lens and bulb socket assembly will drop right out. Sorry, I do not know the bulb size.
Old Jan 15, 2012 | 09:43 PM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
They use 194 bulbs. If you have the third light in yours, it uses a smaller 74 bulb.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
89FormulaMan
Aug 10, 2015 10:01 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
