110 mph speedo swap
Old Jan 24, 2012 | 04:24 PM
eboula24's Avatar
Car: 1984 camaro z28
Transmission: 5 sp
110 mph speedo swap
i have an 84 z28 with the 85 mph speedo in it, and was at the local u pull it place today and saw several 110 mph speedos..im assuming most of the cars were in the 85-89 yr range, but some might have been newer..question is..are these speedos compatible with my car which im assuming is cable driven or mech. speedo (idk the difference if there is one) i only want the speedo itself not the whole cluster. anyone know of any issues that might come up with the swap? id hate to pick it up and find it wont work..even if it is only 20 bucks. hopefully its just a simple swap/plug and play so to speak.
Old Jan 24, 2012 | 04:39 PM
my82roc's Avatar
Car: 89 Iroc Convertible
Re: 110 mph speedo swap
Should be plug and play
Old Jan 24, 2012 | 04:46 PM
eboula24's Avatar
Transmission: 5 sp
is that with any year 110mph speedo? im not sure if ill be able to tell what year the camaro i get the speedo out of will be..for some reason i thought they changed from mechanical speedo to the other kind at some point
Old Jan 24, 2012 | 05:41 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
i think 91-92 are electronic.my 89 is mechanical and 110.btw fix the trip odometer before installing.
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
82-89 Camaro speedos are cable driven, 90+ electric. To avoid electrical gremlins, swap in the speedo head only. Plug and play.
JamesC
Old Jan 24, 2012 | 05:47 PM
zenish's Avatar
Engine: 305 tbi
so if i see a 1990 speedometer in a junkyard i should grab it for my future [hopefully] t56 conversion?
Old Jan 24, 2012 | 06:09 PM
JamesC's Avatar
The shape of the 90+ cluster is far different than the 89-. It won't fit without modification.
JamesC
Jorlain
Aug 24, 2022 05:11 PM
beastin91rs
Oct 9, 2015 07:38 AM
Regal105
Aug 23, 2015 03:45 PM
Irocohio
Aug 12, 2015 08:03 AM
