Squeaks, Creaks, Rattles. WHERE ARE THEY?
Old Jan 27, 2012 | 11:23 AM
Maroonz2800's Avatar
Car: 1987 camaro sport (Z28 interior)
Engine: V6, I6, V8, I4, I3
Transmission: auto w/OD, 5-speed, 6-speed
Axle/Gears: u/k
it seems as though though there's a nest of crickets and mice in the car as i drive. The panels rattle, squeak, everytime i hit a bump they shudder. People do post complaints about these sounds. Anyone ever find out what the major perpetrator of these sounds are? I honestly wish i could have a decently quiet ride in this car...
Old Jan 27, 2012 | 11:28 AM
Andrew James's Avatar
Car: 1990 Formula Firebird
Engine: 350 (5.7) TPI
Transmission: WC T5
Axle/Gears: 3.42 POSI
Re: Squeaks, Creaks, Rattles. WHERE ARE THEY?
I take it you are enjoying your 20+ year old vehicle?
Components wear out, and if you install sound deadener, it would make quite the difference.
Old Jan 27, 2012 | 12:27 PM
IROC#1's Avatar
Car: 1988 IROC Z
Engine: 5.7 litre
Axle/Gears: 3.27 Posi with 4 wheel disc brakes
I feel VERY fortunate to enjoy a car without any rattles or creaks (pretty amazing because I know how bad these cars can be).
That being said I would START with new (quality) shocks and struts like bilstein and if your car has t-tops I would then install subframe connectors. Doing both those things will help tremendously with what you are experiencing. Installing sound deadener will help with road noise but will NOT help with the creaks and rattles you are referring to.
Old Jan 27, 2012 | 12:59 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Sub-Frame Connectors (SFC's) will help with most of your noise problems. My car is about as tight as when it was new and I am the original owner (have SFC's).
Old Jan 27, 2012 | 01:31 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
I think it's mostly the seats,on mine anyway,they don't rattle they sq eek when you enter and exit.I did have a problem with the rear stabilizers they would BANG when accelerated,it was the rubber grommets,had them repaired no biggie,also when I hit a bump I would here a
loud rattle in the rear, it turn out my rear calipers where no good they where their just for a ride,replaced rotors,calipers,pads on both sides and now it's nice and tight and quiet.
Old Jan 27, 2012 | 01:48 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
I just turn the radio louder if I hear them but then again my old 85 was missing alot of floor and the subframes where holding it together from folding in half LOL. It was annoying but then again its expected due to age
Old Jan 27, 2012 | 01:54 PM
mantaguy's Avatar
Engine: 5.0 EFI
I was told to turn my radio up,I'm one of those guys who cant stand squeaks and rattles also.
Old Jan 28, 2012 | 01:56 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
My previous front pads came without anti-rattle clips, resultant rattle was annoying. New pads had them, problem solved.
Make sure your steering column mount bolts are tight - 2 big ones holding u-bracket to body, and 4 smallers ones from column to u-bracket, that was another big one for me.
Old Jan 28, 2012 | 07:27 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Many issues are associated with the windows/doors:
https://www.thirdgen.org/forums/body...servation.html
JamesC
Old Jan 28, 2012 | 08:45 AM
Hal87's Avatar
Car: '84 Firebird TA & '87 Camaro LT
Engine: 350 V-8 & V-6
Axle/Gears: 3.23 & 3.42
I got rid of a lot of squeaks just by replacing hinge pins. Weather stripping on the doors helped too. Next to go on are SFC's
Old Jan 28, 2012 | 08:58 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
I had a weird noise in my 83 when I put it in gear with the brakes on. Looked but could not find it. Then one day I had the rear wheel off cleaning it up and noticed the lower spring perch was pretty rusty. Cleaned that up with wd and wet sand paper and put a little grease on it-solved that sqeeeek
Old Jan 28, 2012 | 09:01 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Start with a good quality weld in subframe connector to stiffen the car and then attack the loose things in your car. Have a friend drive so you can crawl around and listen to where they come frome..
Old Jan 28, 2012 | 09:22 AM
Edwardgp's Avatar
Engine: 454-350
I did notice a big difference with my sfc welded from back to front. This stiffened the car up quite a bit.
Old Jan 28, 2012 | 09:39 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Also just replaced my front sway bar bushes, old ones were shot and rubber spooging out the sides. Got rid of the low pitched soft clunks it used to make on a bumpy road.
Old Jan 28, 2012 | 11:03 AM
Edwardgp's Avatar
Engine: 454-350
I am headed out to my shop right now if I can think of some thing else to help I will post it up here later. Good luck keep looking.
Old Jan 28, 2012 | 12:20 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
i completely dissassembled my interior,no screw was tight,and over half were missing .man i had squeaks and rattles EVERYWHERE!!!! but after the reassemble. no more rattles!
Old Jan 28, 2012 | 12:48 PM
matts86cam's Avatar
Car: 1986 chevy camaro z28 coupe
Engine: crate 355
Transmission: 700r
i tried that too Rusty Vango, even bought new panel screws, but the damn thing still rattles lol. One guy on the board here wrapped the interior plastics in leather or vinyl i cant remember, but said it was super quiet after that
Old Jan 28, 2012 | 10:45 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Believe it or not, but over tightening the interior screws will cause squeaks and rattles. Just snug them up and call it a day.
Old Jan 28, 2012 | 11:10 PM
mantaguy's Avatar
Engine: 5.0 EFI
Learned my lesson on that one,it scares me to over tighten them,I can here the plastics cracking now.
Old Jan 28, 2012 | 11:37 PM
Carlos773's Avatar
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
SFC's, add some padding to the back of the interior plastics and visually check everything that its not loose.
Worked for me.
Old Jan 29, 2012 | 01:29 AM
Axle/Gears: u/k
Thanks a lot you guys, so far its tighten (snug) anything up, pad w/e you can, and check out the SFC, will do! but yes I guess i do have to keep in mind, the car is 25 years old!
Old Jan 29, 2012 | 02:41 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
I added some dynamat which reduced most of the rattles. SFC's will provide much needed frame reinforcement. it should be the first mod you do.
Then again, the only thing I hear is the radio and the Q-jet when all 4 barrels open.
Old Jan 29, 2012 | 04:08 PM
Edwardgp's Avatar
Engine: 454-350
I just got back in after a good day of rolling around my Camaro. I looks like when she was being built they had a guy for each side on the line. Had to tighten a lot of bolts on the pass side and the drivers side was fine. K member included. Probably be quieter now.
sjorgens
Oct 1, 2015 07:54 PM
mustangman65_79
Aug 8, 2015 12:07 PM
CD MaroMan 91
Car Audio
Oct 27, 2001 04:19 PM
zedder 1 9 9 0
May 16, 2001 07:20 AM
rsilver
Dec 10, 2000 04:19 AM
