Automatic locks are NOT working!!!
Old Jan 31, 2012 | 03:40 PM
redzee85's Avatar
Car: 1985 z28
Engine: 5.0 LG4
Transmission: Built 700R4
Axle/Gears: 3.08
Hello everyone, on my 85 Z28 I have automatic locks and when I push the lock/unlock button on the door it makes the noise like its moved the rods on the inside of the door to unlock/lock it. But it just makes the noise and doesn't actually do anything, I have to manually do it.
Anyone have any idea why it would be doing this?
Old Jan 31, 2012 | 04:09 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Automatic locks are NOT working!!!
If you do a you'll find a multitude of threads about fixing this. Essentially it boils down to having to take the door panels off and hitting everything with de-greaser then re-greasing all the joints.
Old Jan 31, 2012 | 04:20 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Old Jan 31, 2012 | 05:19 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Try spraying WD40 or silicone spray on the lock slides beforeyou start ripping the door panels apart. In most cases this solves the sticking issue (just grime & dirt build up over the years).
Old Jan 31, 2012 | 11:21 PM
Dmans85's Avatar
Car: '85 Z28
Axle/Gears: 3.23 posi
You might be able to see your problem without full removal. Gently pull out the door panel from the end that is furthest away from the front of the car. The lower part of the panel is only attached by plastic connectors that hold up without breaking. With a good flashlight you might be able to spot the problem. Won't hurt to try. Its worked for me
Old Feb 1, 2012 | 07:08 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
While you're in the door, you might consider some of the following info:
https://www.thirdgen.org/forums/body...servation.html
JamesC
Old Feb 2, 2012 | 09:14 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
And just to help with the search, you are looking fr info on POWER locks, not automatic locks.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
