hatch pull down
Old Feb 9, 2012 | 07:48 PM
neverfinished88's Avatar
Car: 88 Camaro
Engine: 5.0
Transmission: 700r4w/shift kit
Axle/Gears: 10 bolt
hatch pull down
i have a 88 camaro and my hatch pull down doesnt work and i dont think i can get it to unless i redo the whole thing and i think that is what is making water come in the back i was wondering if i could could take the whole thing out and put in just a regular lock and and make it seal shut
Old Feb 9, 2012 | 08:39 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: hatch pull down
You could,but your risking shattering the glass.I would just fix it, that's less expensive than replacing that glass.
Old Feb 10, 2012 | 07:35 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: hatch pull down
https://www.thirdgen.org/tech/hatchpulldown.pdf
It's not that hard to repair your hatch puldown unit. I have all the parts available to repair these.
Lon Salgren
Old Feb 10, 2012 | 09:10 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: hatch pull down
you will find, that we all prefer you repair the pull down unit.as it isnt hard to do.and as previously stated,its cheaper than a hatch glass by far
Old Feb 10, 2012 | 09:31 AM
cliff1970's Avatar
Car: iroc z
Re: hatch pull down
and lonsal will have your parts to you very quickly. good guy to deal with
Old Feb 10, 2012 | 10:39 PM
Car: 88 Camaro
Engine: 5.0
Axle/Gears: 10 bolt
Re: hatch pull down
ok thanks for everything i will try and do that but i think the wiring is all messed up is that hard to fix or rewire
83 Crossfire TA
Jan 3, 2016 01:26 PM
90formulaVortec
Exterior Parts Wanted
Sep 7, 2015 07:17 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
scottmoyer
Sep 7, 2015 07:06 PM
90formulaVortec
Sep 7, 2015 06:54 PM
