Hazard button broke
Car: 89 GTA & 76 T/A
Engine: 5.7/455
Transmission: GTA Auto/76 T/A 4speed
Hazard button broke
Well today I climbed into my GTA and my right knee hit the hazard button on the column and it snapped off. It looks like the button, spring, inner shaft and screw are intact and there is a broken off piece from inside the column attached still. Anyone know what part I need inside the column? I need to replace the turn signal cam and wiper/washer/turn signal arm anyway with my new parts but will also no need this piece now.
Car: `86 SS / `87 SS
Re: Hazard button broke
Turn signal switch. Not too bad once the wires are fed back down the column.
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
To take a look at what you need you can see the part on e-bay.
sjorgens
Oct 1, 2015 07:54 PM
