Auto Shift Indicator?
Old Feb 27, 2012 | 04:50 PM
coryprine's Avatar
Car: 85 Camaro Z28
Engine: 5.7 TPI
Can anyone tell me if there are certain year camaro auto shift plates that I can put in my 85 Z28. The current plate does not have a "moving" indicator to show the gear selected nor does it light up.
I want to try and find a light up plate that has the red/orange gear indicator.....Thanks...
Old Feb 27, 2012 | 05:02 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Re: Auto Shift Indicator?
88 up I think but I bet your light is blown so that's why it's not lighting ip
Old Feb 28, 2012 | 04:36 PM
my82roc's Avatar
Car: 89 Iroc Convertible
88-92 have the moving indicator
Old Jun 5, 2013 | 10:44 PM
Mz.Makiz75's Avatar
Car: 1989 Camaro RS
Engine: V8 5.0
Transmission: Automatic
hello, i have a 89 camaro rs and i want to replace the auto shifter indicator, mine lights up. I dont know how to remove the **** from the shift gear stick. Mine has a middle button that u push down in order to move the gears. I dont want to mess it up, so how can i replace just the indicator and which other years would fit on mine? I would really appreciate it if i can get some help.
Thank you
Old Jun 6, 2013 | 06:29 PM
my82roc's Avatar
To get the **** off you have to pull out the U shaped staple clip.It is on the front of the **** and faces the radio.Pry it out with a thin flathead screwdriver and then the **** will come off
Old Jun 6, 2013 | 06:33 PM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Axle/Gears: G92
Once the shift plate comes off, you will notice the shift indicator section is sealed in some sections. https://www.thirdgen.org/forums/inte...ou-remove.html
Old Jun 6, 2013 | 07:33 PM
FinallyGotMyZ's Avatar
Car: 1986 Chevrolet Camaro Z28
Engine: 305 5.0 L TPI
Transmission: 700 R4
OK, so to make sure I understand, my '86 does NOT have a gear indicator? I know the bulb is good because I just replaced it.
Old Jun 8, 2013 | 02:06 PM
my82roc's Avatar
Correct......86 does not have a moving indicator
Old Jun 8, 2013 | 03:16 PM
Mz.Makiz75's Avatar
Car: 1989 Camaro RS
Engine: V8 5.0
hello me again, ok mine had the clip or staple looking thing in the front of the shifter **** towards the stereo. I took it off, and i can't seem to pull the **** off, I twisted to the left and to the right and even tried pulling it up. It wont move to any direction. Is there a secret to taking it off? please help again. Oh and by the way i sprayed with WD40 and left its soaking.
Thank you
Old Jun 8, 2013 | 03:33 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
I have never removed the **** with the staple in it but it
would be worth your time to pull the shifter top button off
and LOOK down inside and check to see if you have a
snap ring holding the shifter ball to the shaft................
I know the other ball removal threads say to just remove the
staple and the ball will just pull off but I would have a looksee
inside of it for a snap ring................
My 84 had no staple only snap rings.
Old Jun 8, 2013 | 03:38 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Thank you
Once the u-clip is removed the **** is removed by pulling straight up off the stick.
Keep your face out of the way.
Old Jun 9, 2013 | 05:03 PM
Mz.Makiz75's Avatar
Car: 1989 Camaro RS
Engine: V8 5.0
ok you guys, thank you im going to try it again, lol and i hope i dont end up socking myself,lol!
Old Jun 9, 2013 | 09:26 PM
Mz.Makiz75's Avatar
Car: 1989 Camaro RS
Engine: V8 5.0
GOT IT!! I KEPT PULLING IT UP AND MOVING THE SHIFTER FROM PARK TO NEUTRAL AND KEPT FIGHTING WITH IT, AND I FINALLY GOT! I HAD TO PULL IT UP AND JUST KEEP PULLING IT UP. AND NOPE I NEVER SOCKED MYSELF. LOL THANK YOU GUYS FOR HELPING ME.!
Old Jun 9, 2013 | 09:54 PM
Mz.Makiz75's Avatar
Car: 1989 Camaro RS
Engine: V8 5.0
OK NOW I NEED A NEW GAS TANK, DAMN! FOUND A LEAK AND A TEMP REPAIR FROM PREVIOUS OWNER. BUMMY
Old Jun 10, 2013 | 07:26 AM
OK, thanks. Wow, that seems a little strange on GM's part, but oh, well. At least I can quit stressing about it now.
junior419
Apr 7, 2025 11:35 AM
F-body driver
Mar 6, 2023 11:44 AM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
88rscamar0
Sep 23, 2015 09:08 PM
