rearview mirror removal w/o windshield damage
Car: 1986 chevy camaro z28 coupe
Engine: crate 355
Transmission: 700r
I glued that little metal mounting piece onto the windshield backwards
anyone know how to get it off the windshield? I though about a heat gun but wasnt sure if it would mess up the windshield, warp that film they have in them.
Any ideas?
and I dont want to just glue another mount onto the old one. Trying to bring it up a notch inside and that wouldnt help any.
anyone know how to get it off the windshield? I though about a heat gun but wasnt sure if it would mess up the windshield, warp that film they have in them. Any ideas?
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: rearview mirror removal w/o windshield damage
I learned the hard way YEARS ago that a heat is bad news! You know Safety Glass has a thin sheet of plastic in the middle to prevent shattering right? Turns out that if you heat the glass up, that layer will suddenly "pop" & you get big air bubbles between the glass sheets. UGH!
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
http://www.ehow.com/
this site will tell you,"How to remove a rear view mirror bracket"
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Here's what my small town automotive glass shop recommended (and the method worked fine for me, though my heart was in my throat the whole time):
Hit the button evenly with a propane bottle torch for a few seconds, then using pliers, gently twist. The operation took several repetitions for the button to twist free. No ill effects.
JamesC
JamesC
Engine: 5.0 EFI
TORCH,now that's scary. Joined: Aug 1999
Just the handheld bottle type, which is easily manageable.
JamesC
JamesC
Engine: crate 355
Transmission: 700r
Thanks for the advice.
ehow said a blowdryer but I think I will just hit it with a torch for a few seconds, 15 or 20 and take a crescent wrench to it. I am sure my butthole will be puckered the whole time lol I really dont want to buy a new windshield. I will let you know how it turns out.
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
What about the stuff they use to remove "super glue/crazy glue" when folks glue their body parts together by accident?
Is it some kind of solvent like acetone/laquer thinner etc????
Google is your friend:
http://www.spazzticcrafts.com/remove-super-glue.php
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
i had to put the mirror back on my 86 last summer, the new adhesive package specifically said that if you mess up and glue the button on backwards, buy another button and glue it to the other. Dont even try to remove it.
A glass shop may be able to held as James suggested, torch sounds a bit iffy, but there are always tricks of the trade.
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
