adding power windows oem stuff
Old Mar 24, 2012 | 08:11 PM
92camarorv6's Avatar
Car: 92 camaro rs
Engine: 3.4v6 sc
Axle/Gears: 9 bolt 3.73s
ok i have a 92 camaro no power any thing in it. Im about to get a set of doors how hard is it two add power windows ? useing all the oem stuff its 87 or maybe a 88 with a 2.8 v6. and how much wait will it add ? and how hard would it be to add the power locks two my car is 3180 with me in it it dont need alot more wait thanks for any info.
Old Mar 24, 2012 | 09:07 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: adding power windows oem stuff
ck. SPAL website . they have kits for windows & door locks . i have both on my car . i'm happy , good luck . weight for both full kits , less than a 6 pack .
Old Mar 24, 2012 | 09:32 PM
algershick's Avatar
You'll need to research wiring diagrams to see exactly what you're going to have to add, and where. If you want factory controls, you're going to have to either cut up your console or find a piece from a factory power optioned car. Relay/wiring will be the difficult part depending on your ability, the project won't be that bad as long as you get a set of doors with functioning power options.
Old Mar 24, 2012 | 10:02 PM
Car: 92 camaro rs
Engine: 3.4v6 sc
i have a full parts car to pick from hints why im willing to try and do it
Old Mar 25, 2012 | 07:20 AM
Car: 92 camaro rs
Engine: 3.4v6 sc
any one help?
Old Mar 25, 2012 | 12:11 PM
algershick's Avatar
If you have a complete parts car with everything that you need, I don't think anybody could give you any better advice than to just swap all of the parts into your car.
Old Mar 25, 2012 | 01:27 PM
82tarecaro's Avatar
I am pretty sure the harness is separate in the car from the main harness. Separate it out, see how it is installed, and remove it. Then put it in your car, along with the doors and switches. You have the best help available - a car that you can take apart to see how everything works.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
stalkier
Aug 21, 2015 01:54 AM
stalkier
Aug 13, 2015 12:59 PM
