stripping interior and ebay racing seats..questions
Old Mar 25, 2012 | 08:14 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
questions..
stripping the interior, is there anything i need to watch for? pros? cons?
now..the ebay racing seats
how are they?
do they fit?
i know ill have to drill out holes for the brackets..anything else to watch for?
Old Mar 25, 2012 | 08:18 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
Re: stripping interior and ebay racing seats..questions
https://www.thirdgen.org/forums/body...ace-seats.html
found this..is this what im looking at?
how about Bride racing seats? how do those fit?
Old Mar 26, 2012 | 12:06 AM
Starbug's Avatar
Car: '89 Firebird Trans Am WS6 - project
Engine: Building a 400 C.I. SB Chevy V8
Transmission: manual T5
Axle/Gears: posi rear end
My only tip is when you go to remove the center console, take out your radio/HVAC controls and then the pod they sit in before you remove your center console. Other than that, you should have no problems removing your interior.
Oh, and be careful that you don't sit on the seat mount bolts sticking up through the floors! They can cause some hurt...lol. I'm a klutz speaking from personal experience. D'oh.
Good luck and have fun!
Old Mar 29, 2012 | 04:19 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Um, no. Doesn't work that way. Trying to remove the radio pod before the console is a good way to break the pod (been there, done that... pod was crap anyways so I didn't care). You remove the console first by undoing all of the bolts on the lower section (there's one on the shifter if an auto), slide it towards the back, remove the park brake hand grip and pull the brake lever up, lift the console up at the back, and slide it out from under the radio pod before lifting it up and completely out.
Old Mar 29, 2012 | 06:58 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
What do you mean by stripping,I know your removing the seats what else?
Old Mar 29, 2012 | 11:45 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
carpet..back seats..plastic panels in the back..gonna keep the dash and center console
Old Mar 30, 2012 | 07:59 PM
mantaguy's Avatar
Engine: 5.0 EFI
When I did mine,I kept all interior screws in one container and all the nuts and bolts in another.Then I gave them a coat of semi flat before I put them back in.See any surface rust,sand it and coat it,Just really gave it a good cleaning before anything went back in.
Old Mar 30, 2012 | 08:08 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
will definitely do that
any tips for getting the black **** off? lol
Old Mar 30, 2012 | 08:27 PM
mantaguy's Avatar
Engine: 5.0 EFI
The glue ****
Old Mar 30, 2012 | 11:22 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
yeah that ****
Old Mar 31, 2012 | 08:24 AM
mantaguy's Avatar
Engine: 5.0 EFI
I tried using gasoline but that ****stinks,so I bought this stuff called Goof Off,now that **** really works,it comes in a spray or a small lighter fluid type can.The **** in the can works better that the spray ****.
1992 Trans Am
May 10, 2023 07:19 PM
AussiePr0nCar
Mar 6, 2020 04:04 PM
Vintageracer
Jan 10, 2020 05:33 PM
deracer
Apr 11, 2016 12:04 AM
