Hatch Mechanism trouble
Old Mar 31, 2012 | 12:59 PM
Lmancha96's Avatar
Car: 1992 Camaro (Z28 Clone)
Engine: LB9|TPI
When i bought the car the hatch was working normally but after opening and closing it a couple times the motor failed to pull down the hatch or atleast thats what i thought had happened.
Its been about two months now since i have left it like that but today i finally decided to take a look at it. It turns out it is not the hatch motor, that works fine, i can manually make it go up and down by pushing the little button. The conclusion i have come to is the latch thing is not working correctly. I think it is stuck in the down position or something. Am i right?
So my question is how do i make the latch come up? I tried prying at it with a screwdriver but was afraid i would break something so i left it alone.
Old Mar 31, 2012 | 02:40 PM
Red Zed's Avatar
Car: 1987 Camaro Z28
Engine: LB9
Re: Hatch Mechanism trouble
The latch part on the hatch? did you try manually opening with the key?
Old Mar 31, 2012 | 02:43 PM
Lmancha96's Avatar
Engine: LB9|TPI
Im not exactly sure what it is called but I tried with the key and the button and nothing happened.
Old Mar 31, 2012 | 03:43 PM
DeltaElite121's Avatar
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Mine was once, actually. Could be right. My first hatch mechanism ended up stripping out also, though.. hense why it didn't work.
PurelyPMD
May 5, 2016 04:57 PM
punkmaster98
Sep 30, 2015 11:01 AM
IROCZDAVE (88-L98)
Sep 22, 2015 02:22 PM
Johnoooooo
Sep 22, 2015 08:55 AM
webeeZ28
Sep 14, 2015 12:00 PM
