How Effective ???
Old Apr 9, 2012 | 06:55 PM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
How Effective ???
Ok so I'm looking into redoing the floors with por 15 an rhino line the interior floor the underneath has already been done but I highly doubt they ever did the interior side of the floor. I do have one spot of rot building up that will need to be cut out an patched up has anyone done it to there cars an how great does the por 15 or rhino liner work I do live in new England (Ma) to be exact. roads here do get really salty an wet, that's how my 89 gta got ruined along the rockers, an frame rails
Old Apr 9, 2012 | 07:04 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: How Effective ???
Sounds like it should work good. The one member I believe he lived in England sprayed it on underneath but I think it takes a special gun.
Old Apr 9, 2012 | 09:16 PM
Engine: LR4 4.8
See what I was gonna do I buy the big tub of it an use a paint brush to lay it out of course remove all surface rust first I was gonna do from the top of the toe board all the way back to the trunk well should make it rust free then I'll have a rust free third gen that will last for ages to come
Old Apr 10, 2012 | 07:06 AM
Edwardgp's Avatar
Engine: 454-350
Maybe even touch up the bad areas first with some good paint.
Old Apr 10, 2012 | 02:47 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
If you're going to go that far with the POR and bedliner, you might as well go a little further and do the wheel wells and along the frame sections up front, inside the trunk well and back in behind the quarter panels. If you haven't already done the wheel wells, get the rubber crap off with a wire brush on a grinder and do the same there as well.
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
Damon
Sep 26, 2015 04:29 PM
James Sutton
Sep 23, 2015 01:56 PM
billybob6110
Sep 23, 2015 01:30 PM
ASE doc
Sep 22, 2015 03:13 PM
