Dash cluster
Old Apr 10, 2012 | 05:35 PM
donnas88camaro's Avatar
Car: 1988 Camaro
Engine: 2.8
Transmission: auto
Dash cluster
I am trying to remove the dash cluster on my camaro. Its hard to get at the speedo cable. Is there a trick to get at it easy? Would droping the steering wheel help? Thanks
Old Apr 10, 2012 | 06:20 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Dash cluster
Remove the hush panel under the wheel and you should be able to snake your hand up and release the cable
Old Apr 10, 2012 | 06:28 PM
Car: 1988 Camaro
Engine: 2.8
Transmission: auto
Re: Dash cluster
Thanks so much. Thats the bottom cover under the steering wheel that your talking about right?
Old Apr 10, 2012 | 07:24 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Dash cluster
Yeah, the panel that's right above your knees when you're driving
Old Apr 10, 2012 | 07:36 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Re: Dash cluster
use a long flat head screw driver its held in by a pressure clip, use the screw driver to push the tab toward the back of the cluster, light tug on the cable and it will come loose, if you need a pic lemme know!
Old Apr 10, 2012 | 08:31 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Dash cluster
Info/pics may prove helpful:
https://www.thirdgen.org/forums/faq-...-fix-pics.html
JamesC
Old Apr 10, 2012 | 10:34 PM
Car: 1988 Camaro
Engine: 2.8
Transmission: auto
Re: Dash cluster
Thank you everyone!!!!! will try again tomorrow. thanks for the help.
Vintageracer
Sep 24, 2017 12:34 PM
rusty vango
Sep 29, 2015 02:44 PM
Eric-86sc
Sep 28, 2015 11:37 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
