Seat Belt Guide
Old Apr 16, 2012 | 04:14 PM
Blaze of Glory's Avatar
Car: 92 Firebird
Engine: 3.1L V6
Seat Belt Guide
Attached to the head rests is a plastic loop that is used to keep the seat belt properly positioned.
I removed the passenger side loop and cannot, for the life of me, put it back. There are two screws and I can't locate the holes. I have take off the driver side loop many times and didn't have a problem putting it back. Is there a trick to putting it back? Is it possible something inside the headrest broke?
Old Apr 16, 2012 | 04:33 PM
Cleric69's Avatar
Car: '87 IROC-Z
Engine: 350ci
Transmission: 700r4 rebuilt
Re: Seat Belt Guide
Can't find the holes, you say? I have that problem more than I'd like to... :-p
But, I know what you're talking about- the holes are there, but sometimes the holes in your headrest material and the holes in the inner headrest will drift out of alignment with each-other. Just keep poking around. The piece is pretty solid, but if needed, you should be able to drill new holes.
And don't worry about screwing the wrong hole- you can always back it out and try again. :-D
Old Apr 18, 2012 | 07:58 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: Seat Belt Guide
Use a long nail (as in wood nail), punch, allen wrench, or awl (for making holes in things like leather) and line up the holes before putting the lower screw in first.
At least the wood inside your headrest hasn't split like mine has on the driver's side . Yes, they screw into a wood block. Apparently, anyways (never seen it myself).
Old Apr 18, 2012 | 09:50 PM
Hal87's Avatar
Car: '84 Firebird TA & '87 Camaro LT
Engine: 350 V-8 & V-6
Axle/Gears: 3.23 & 3.42
Re: Seat Belt Guide
Took off the upholstery on mine to find the holes - actually just a sheet metal bracket inside
Old Sep 20, 2012 | 11:09 AM
Gary Simonds's Avatar
Car: 87 IROC-Z
Axle/Gears: 2:73
Re: Seat Belt Guide
i have the same problem. the bottom holes don't exist!! my headrest was recovered and the only hole i find is the top. the bracket almost seems bent or crooked.
ZMWojnar
Interior Parts Wanted
Sep 24, 2015 08:34 PM
scottmoyer
Sep 20, 2015 11:54 AM
MORREALE5
Sep 13, 2015 09:01 PM
iroczguy86
Sep 13, 2015 02:22 PM
MORREALE5
Sep 10, 2015 08:58 AM
