Headliner replaceed and seats repaired
Old May 1, 2012 | 06:58 PM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
I've had the entire interior out except for the dash board for a complete redo of late. New carpets and thermo insulation was installed previously, different thread, and now the rest has been finished.
The front seats were dirty with the driver's side having several tears and rips due to use. These were repaired by a local shop that took weeks to locate the correct matching material. The overall result was fantastic. Hard to see from the pics but they look like new compared to what 26 years of wear did to them.
Redone.
Before.
The headliner was replaced with a set from Classic Industries that had the headliner material, sail panels, and sun visors.
Here's what it looked like when I took it out.
Old May 1, 2012 | 07:00 PM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
Re: Headliner replaceed and seats repaired
Here is what the new vs old looks like.
This is a picture of what the innards of a sun visor looks like. Pretty cheap I think.
Old May 1, 2012 | 07:03 PM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
First I used the adhesive not made by 3M, a mistake. use the adhesive in front in this picture not the one behind.
You are going to need clips, too 3 of them. CI has clips for the front part of the headliner near the windshield.
And while your at it get the clips that keep up the side rails on the upper sides of the doors. They can easily break after a couple decades. I found a bag at my local auto parts store.
Old May 1, 2012 | 07:09 PM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
This was a lot of work getting all this done. The scariest part is gluing the headliner material to the headliner panel. You get one chance to do it right. If the headliner panel has ANY marks or defects - if it is not perfectly flat and true - it will show up on the visible side of the headliner after the material has been applied. Push marks, holes, dents, scrapes, ALL SHOW UP. Believe me, I have some uneven spots and it shows, not much but my headliner panel was in decent shape to begin with. If you think you have any questions about your headliner panel, toss it and get a replacement.
Be careful with the seat belt cover clips that attach to the roof part of the headliner. They can be fragile, too. Luckily I did not break mine and I hope I never have to touch them again.
I still need to take a pic of the finsihed product.
Old May 1, 2012 | 07:25 PM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
Here is the finished product. BTW the rear seats were untouched.
Old May 1, 2012 | 09:27 PM
89iroc89's Avatar
Car: 1991 firebird GTA
Engine: 305 tpi
Transmission: 5spd
Axle/Gears: 3.42 posi
I really hope you sprayed that thing with 3M till all it was gone... I just redid mine over winter, and one hot day this spring and it all fell down....
Old May 1, 2012 | 09:57 PM
ZeBatmobile's Avatar
Car: 92 Z28
Engine: 350 (ZZ4 Block) '193 heads.
Transmission: WC T-5
Axle/Gears: 3.42 Posi
yea i tried the orange can earlier this year and made it way worse. I can stand it wheni have the windows down cruzin and its flappin on top of my bald head in the wind... ugh
Old May 2, 2012 | 07:40 AM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
I used about 3/4's of the orange can and the entire can of the 3M adhesive. It seemed like the 3M adhesive stuck faster and held stronger than the Permatex stuff. Figure on using two cans of the headliner adhesive and at $16 a can for the 3M product can be costly. The headliner material, the sail panels, and visors cost about 200 hundred with another $15 in clips; it was not a cheap job. This was my first crack at a headliner so I took my time being very careful on prep work and making sure I had what I needed to complete the job.
Old May 3, 2012 | 01:39 PM
1Aauto's Avatar
Former Sponsor
Your interior looks pretty good. nice job.
Old May 3, 2012 | 04:27 PM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
Thanks. I appreciate the kind words. I believe I got new carpets from 1A Auto a few months ago. It all came together better than I expected.
Old May 3, 2012 | 05:17 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
You should remove the starting instruction label from the d/s sun visor and put it on the new one.
Old May 4, 2012 | 10:46 PM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
Too late, in the trash. The vanity mirror is in the parts bin though.
Old May 4, 2012 | 10:50 PM
mantaguy's Avatar
Engine: 5.0 EFI
Shame!!!that would have been an original piece,nice to have.
Old May 7, 2012 | 07:17 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
Those aftermarket visors are thicker and more padded than the originals, but personally I think they look and feel higher quality.
Old May 7, 2012 | 07:53 PM
mantaguy's Avatar
Engine: 5.0 EFI
I think your right,maybe because their new and not dry rotted,I peeled the starting instructions off my old ones
Trying to keep it as stock as possible.
Old May 10, 2012 | 09:44 PM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
Stock? Yes, most definitely. But I think I know how to start mine!
Old May 15, 2012 | 05:57 PM
D&S 85 IROC's Avatar
Car: 85 IROCZ
Engine: 350 TPI with a fast EZ efi
Transmission: t-5 conversion
Axle/Gears: 3;42
I have the same color interior, and my seat look just like your. Where did you find new material? Thanks
Old May 15, 2012 | 09:25 PM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
Good question. The first lot was too green so the local shop where I had it done found the correct '86 gray at a second vendor. I'll have to call him and ask him from where he got the material. Give me a day or two to call him.
Old May 16, 2012 | 12:51 PM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
My local shop got the material from Miami Corp. in Cincinatti, Ohio. It was in stock. They are a direct vendor to businesses, not to the general public so you'll have to find an upholstery shop to get it.
http://www.miamicorp.com/default.aspx?Page=Home
Veaceonee
Sep 29, 2016 08:15 PM
MORREALE5
Sep 13, 2015 09:01 PM
iroczguy86
Sep 13, 2015 02:22 PM
Nick McCardle
Sep 10, 2015 08:36 PM
