How do I tighten dash?
Old Jun 4, 2012 | 05:08 PM
jhuebner's Avatar
Car: 1987 Trans Am
Transmission: STOCK
How do I tighten the dash on a 87 trans Am? It's loose and shakes badly. I just dont know how to tighten it.
Old Jun 4, 2012 | 05:22 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: How do I tighten dash?
If you mean the dash cap, there should be some screws in the fronts of the defroster openings on the top near the windshield, and several under the front lip nearest you pointing upwards. That's all holding it on and tightening or replacing them should do it unless you're missing the foam pads under the dash pad
Old Jun 4, 2012 | 05:23 PM
jhuebner's Avatar
Car: 1987 Trans Am
Transmission: STOCK
Thanks man! Ya I ment the dash pad. Ill try it out.
Old Jun 4, 2012 | 07:44 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
OK jhuebner glad to see you back.
Old Jun 5, 2012 | 06:18 AM
made2drag's Avatar
Car: 88 ta
Engine: tpi 305
yeah there are several little 7 mm bolts/screws that loosen up over time. i took my pad off and most of the bolts were loose. another thing i will be doing is buying some headliner material and placing it under things that rattle...like the pad and the a piller trim and other things
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
86IROC112
Nov 7, 2015 06:50 AM
gord327
Oct 3, 2015 01:25 PM
Fanatic1074
Oct 2, 2015 03:47 PM
lewandom
Oct 1, 2015 08:15 AM
