Anyone have a "WoW" factor in their interior (post pics)
Old Jan 19, 2013 | 12:10 AM
  #251
basshead208's Avatar
Car: 86 IROC Z28
Axle/Gears: posi 4 disc 2.73
Re: Anyone have a "WoW" factor in their interior (post pics)
looking at the pics on ebay, each lay has a tab and wire. the tab extends over the edge of the guage, the guage edge curves up so you want to grind that edge down with the dremel so the tab exits flat out the face.
Old Jan 19, 2013 | 12:18 AM
  #252
Car: 86 IROC Z28
place 2 sided tape onto the guage face then slide the lay over the needle CAREFULLLLLLLLY and press down onto the face. needle goes through hole obviosly. I had a t10 bulb that was burnt and soldered leads onto it then shaved the solder down and hijacked one of the stock bulb placements so they turn on normally with the headlight switch. verify pos+ with test light. You can also remove the green pieces for the turn signal bulbs and replace the bulbs with any color t10 led you want. get a t10 5050 if you want it bright or a t10 3528 for standard brightnes.
Old Jan 19, 2013 | 03:04 AM
  #253
kmcn47's Avatar
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
ahhhhh now I'm getting it, i didn't think the tabs would be a big problem, figured they'd be thin and you could just fold em out of the way, and i figured you'd slide the overlay over the needle, just thought for a minute that it would be too thick, or might tear, never had my speedo apart so i don't know how tightly the needle is against the gauge
Old Jan 19, 2013 | 08:17 AM
  #254
Ruckusz28's Avatar
Car: 1986 IROC-Z
Axle/Gears: 4:10
I too had to modify the gauge dish. I actually used some super 77 spray adhesive and molded the overlay in with the help of my heat gun. Mine were the same and were selectable from green to blue. I thought he blue looked better. There is this ugly bulky intensity **** / on off switch. I desoldered it, made it permenantly blue and hard wired it to the illumination circuit (brown at switch).
I asked the store owner if they had red. His response was that they were in research and development lol.
Thanks for the compliments. I'm sure I'm not the first or last to have these.
Old Jan 19, 2013 | 08:20 AM
  #255
Ruckusz28's Avatar
Car: 1986 IROC-Z
Axle/Gears: 4:10
It's nothing a grinder or Dremel can't take care of in 30 seconds. At no point was i worried about these tearing or being damaged. You'll also want to remove all of the 194 bulbs aside from the turn signals while its apart.
Old Jan 19, 2013 | 10:59 AM
  #256
Car: 86 IROC Z28
and you can pull all the guages out so its easier to grind em except the speedo, do it in the dash. and there is the two little flat head screws on the speedo face that you will need to remove so they can go back in over the lay. i dond know if all the lays are like mine but when i slid the needle through the holes i had to pop the circle base of them through each lay, very tight clearance. dont be discouraged, the blue/white/red and indiglow lays are a nice upgrade from stock.
when i had led swap first they were not so bright and tended to flicker sometimes with vibration( its my vol ***** fault, when i can get 1/2" window flex)
i will post a pic of them blue and green in a few
Old Jan 19, 2013 | 11:12 AM
  #257
Car: 86 IROC Z28
day time. off/on blue/on green
ill do it again tonight.
Old Jan 19, 2013 | 07:29 PM
  #258
Car: 86 IROC Z28
at night
very bright
Old Jan 19, 2013 | 07:50 PM
  #259
86'sportcoupe's Avatar
Car: '86 Sport Coupe
Engine: 310"
Axle/Gears: Stock 10 bolt. 2.73's
Heres an update on mine, a new center console lid, eventually i will get a new dash and hopefully a b&m megashifter
Old Jan 23, 2013 | 09:11 AM
  #260
busterbrown's Avatar
Car: 1992 formula firebird
Engine: 355 TPI
Transmission: currently a T-5, eventually a T-56
Axle/Gears: 3:42
I wouldn't call it wow, but it works.
Attached Thumbnails Anyone have a "WoW" factor in their interior (post pics)-image.jpg
Old Jan 23, 2013 | 09:36 AM
  #261
Car: 86 IROC Z28
Better than stock, unique and if I got in your car that's something I'd be checkin out.Good job.
Old Feb 19, 2013 | 06:29 PM
  #262
jaybdaboat's Avatar
Car: 1987 Sports coupe/z28
Engine: 2.8/ swapping 5.3
Axle/Gears: Open 3.42
Anyone else
Old Feb 19, 2013 | 07:39 PM
  #263
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
A member will soon have these painted and in / on his car. Im not gonna spoil who it is. Im shipping the emblems out to him tomorrow.
Attached Thumbnails Anyone have a "WoW" factor in their interior (post pics)-25thannivlsx.jpg
Old Feb 20, 2013 | 01:37 AM
  #264
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Dam id like a set of those minus the 25th anniversary as mine is a 89. They would look sweet
Old Feb 20, 2013 | 09:42 AM
  #265
mac86's Avatar
Car: 1987 Camaro Z28
Engine: Carbed 355
Transmission: Borg Warner T56
Axle/Gears: 4th gen 10 bolt 3:73 Richmond gears
my embossed door panels:
and my custom leather seats
Old Feb 20, 2013 | 10:13 AM
  #266
DethVenture's Avatar
Car: 1992 Camaro RS
Engine: L03 5.0L
Transmission: 700R4 Auto
I know who it is, but I won't spoil either. They are gonna look awesome!
Love the door panels! Unique touch without being crazy.
Old Feb 20, 2013 | 11:20 AM
  #267
mac86's Avatar
Engine: Carbed 355
yea two owners ago, the guy was dabbling in leather design and apholstery so he redid the seats and door panels on it.
Old Feb 20, 2013 | 11:38 AM
  #268
MerethriX's Avatar
Car: Pontiac Trans Am GTA
Transmission: th700
really nice that chevrolet logo on the door!
Old Feb 20, 2013 | 11:59 PM
  #269
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Not something I would rock, but that won't stop me from saying those look very unique and well done.
Old Mar 4, 2013 | 06:24 PM
  #270
Jupiter's Avatar
Car: 82 Trans Am
Engine: 383
Axle/Gears: Built 4th gen 3.42 posi/disc
Just got the last piece of my T56 swap, dude, dude,,, dude
i see you staring at my ****!!!
This is a 2012 Camaro SS Hurst Shifter **** attached to a Hurst Billet Plus shifter. I have a few more things in the works like a black face radio with red lighting and redo the door panels with red stitching.
Old Mar 4, 2013 | 06:28 PM
  #271
Car: 1985 Z28
Really digging this setup! What steering wheel is that?
Old Mar 4, 2013 | 06:37 PM
  #272
Jupiter's Avatar
Car: 82 Trans Am
Engine: 383
It is el cheepo ebay JDM steering wheel with a custon horn button. I used a 2nd gen horn button logo to replace the crappy jdm logo. Perfect fit. None of the aftermarket wheel companies make a bird logo. They all make a Pontiac arrow button but not this so, i made my own.
Old Mar 4, 2013 | 06:44 PM
  #273
Banks4004's Avatar
Car: 1990 Camaro
Engine: 5.0
Transmission: T5 WC
yes I do
Old Mar 4, 2013 | 06:45 PM
  #274
Jupiter's Avatar
Car: 82 Trans Am
Engine: 383
Originally Posted by Banks4004
yes I do
You got your own little car show going on... hehe
Old Mar 5, 2013 | 09:11 AM
  #275
carlos64030's Avatar
Car: 1991 Trans Am GTA
That dash pad...WOW!!!
Old Mar 5, 2013 | 06:53 PM
  #276
LivinLarge's Avatar
Where did you pick up the shift **** from?
Old Mar 5, 2013 | 07:05 PM
  #277
Iroc-EZ's Avatar
Car: 1988 IROC-Z
Engine: 5.7 TPI
Axle/Gears: 2.77
That is freakin nice dude! Love the red and black stitching.
Old Mar 5, 2013 | 07:28 PM
  #278
Jupiter's Avatar
Car: 82 Trans Am
Engine: 383
Thanks guys.
While planning my T56 swap i had visualized this setup but not being artistic i wasn't sure how it would turn out. Some people said it would look like @$$. Well i myself am overwhelmed how nice it came out and how comfortable it is. I got the Hurst ****/boot from gen5diy.com This is a GM Hurst product so it will NOT fit on a Hurst stick. The stick is 5.5" tall and the **** snaps onto it. The mounting holes on the stick, DO match up to Hurst shifters. The boot is integrated to the ****. The boot mounting ring on the bottom is made of plastic and easy to seperate so as to pull the boot out of it. I pulled the boot over my existing console shifter boot mounting ring. It was a tight fit. Make sure to get the stick if you plan to use this ****/boot.
http://www.gen5diy.com/%20Hurst%20M6%20shifter%20covers
The only pic of the stick i have
Attached Thumbnails Anyone have a "WoW" factor in their interior (post pics)-p1010567.jpg
Old Mar 5, 2013 | 09:19 PM
  #279
chevyv8guy's Avatar
Car: 84 firebird
Engine: 355
Transmission: 700r4 stage 2 shift kit 2500 stall
Axle/Gears: 3.42 posi
by far my favorite interior !!!! looks amazing
Old Mar 6, 2013 | 05:15 PM
  #280
white1991rs's Avatar
Car: 1991 Camaro RS/1989 Formula
Engine: 5.0 L03 V8
Nothing unique but mines mint condish
Old Mar 6, 2013 | 05:25 PM
  #281
jdawg1276's Avatar
Car: 1988 camaro
wow has this car even been driven?
Old Mar 6, 2013 | 05:38 PM
  #282
Engine: 5.0 L03 V8
haha yes, I used to drive it everyday, I just keep it very clean.
Old Mar 6, 2013 | 07:26 PM
  #283
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
NICE!!!!
Old Mar 8, 2013 | 12:55 AM
  #284
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
I'm not done yet, but you might see where this is going...
Modded dash
I cut out the center vents in the dash...
modded center console
This is what i did (Deleted the lower vents and wrapped the lower center in leather. On the top i made my own radio plate with smooth step downs to brake it up the rough look and to keep it looking factory. I completely removed the HAVC controls and put the radio in place of the HAVC controls, but that's not all i mounted the radio completely flush with the step down plate, made a space big enough to a accommodate a CD's and also added a 12volt power source left of the holder)
gauge trim rings
Hand cranked on a manual lathe
modded column and wheel
Still got a lot more one off parts in the making *grins*
Old Mar 8, 2013 | 01:06 AM
  #285
Car: 1985 Z28
Nice!
Mint condition porno holocaust interior FTW! Lol.
Old Mar 8, 2013 | 09:31 AM
  #286
BADNBLK's Avatar
COTM Editor
Those are very cool Chris!
Old Mar 8, 2013 | 09:35 AM
  #287
Jupiter's Avatar
Car: 82 Trans Am
Engine: 383
That is SOO phraking HOT it makes me feel dirty... heh
Old Mar 8, 2013 | 10:07 AM
  #288
MerethriX's Avatar
Transmission: th700
is that red stock interior?
Old Mar 8, 2013 | 10:16 AM
  #289
Engine: 5.0 L03 V8
Yep the red is stock. I wasn't sure about it at first but it's certainly grown on me.
Old Mar 17, 2013 | 05:34 AM
  #290
TheFab's Avatar
Car: '89 Firebird
Engine: 2.8l MPFI
Transmission: Automatic
Yeah, I have one.
I've always wanted to have some sort of smooth illumination in my car. Something unique that compliments the interior.
Here's what I came up with. The pics don't really show the color right. It's really a nice orange/red light that fits the stock color of the button illumination very well.
Color-wise this one shows it quite well.
Old Mar 17, 2013 | 11:04 AM
  #291
lanceflame44's Avatar
Car: 1984 Pontiac Firebird Trans Am
Engine: Stock 305
Transmission: Stock 4 speed auto
Originally Posted by TheFab
Yeah, I have one.
is that a LED strip? where did you get it, looks nice!
Old Mar 17, 2013 | 11:24 AM
  #292
LivinLarge's Avatar
Do you have pictures of that setup in the daytime? Are the strips hidden and blended in well or just chillin out there?
Old Mar 17, 2013 | 01:51 PM
  #293
TheFab's Avatar
Car: '89 Firebird
Engine: 2.8l MPFI
@lanceflame44:
Nope, not LEDs. Those are electroluminescent wires. They create a much warmer form of light than LEDs. Also, it doesn't give you any spots, or something. Just one smooth glow. Plus, they aren't as bright as LEDs, so it doesn't disturb you when driving at night.
Another thing I was worried about was reflection in the windows. But as it turns out, the reflections you get when installing the wires like I did are on the far top of the windshield. They don't get in the way at all.
@LivinLarge:
They are not hidden. I don't have any daytime pics but if I don't forget I will take some tomorrow.
The wires in the armrest blend in very nicely. I'm not happy with the one in the dash, though. I'm currently working on a solution and I'll be sure to post results once I'm done with that.
If you're thinking about doing this, keep in mind that you will essentially be destroying your dash pad and armrests. So you should probably buy replacement parts for those in case you want to go back to stock.
Old Mar 17, 2013 | 05:04 PM
  #294
jaybdaboat's Avatar
Originally Posted by salfirebird92
Not wow but not many with double din well where I live
and some door ambient led lights
Red LED Gauges And LED's in the bottom of the Backseats
Are the lights on while driving or some are on or just when you turn the dome light?
Anyone can answer this for me?
Old Mar 17, 2013 | 09:52 PM
  #295
salfirebird92's Avatar
Car: 92 Firebird Formula
Engine: 5.0 V8
They just turn on when I open the Doors or when turning on the Dome light
Old Mar 18, 2013 | 07:46 AM
  #296
jaybdaboat's Avatar
Oh I thought they were always on
Old Mar 26, 2013 | 09:07 AM
  #297
85_ZED28's Avatar
Car: '85 Z28
Yeah, I have one.
That's neat. Looks like Tron
Old Mar 26, 2013 | 10:25 AM
  #298
carattini's Avatar
Car: Pontiac 89 GTA
Engine: 350 TPI 5.7L V8
@lanceflame44:
@LivinLarge:
where can I get those electroluminescent wires?
Old Mar 26, 2013 | 11:28 AM
  #299
MerethriX's Avatar
Transmission: th700
salfirebird92: what are those blue button-like things on left of your radiodisplay?
Old Mar 27, 2013 | 01:14 AM
  #300
Cody Redmond's Avatar
Car: 1987 iroc z
Engine: 360sbc
Transmission: pro built 700r4
Axle/Gears: stock
Those look like leds not hidden very well.could be wrong.
