Shift Knob
Old Jul 7, 2012 | 04:13 PM
Davejs's Avatar
Shift ****
I am finally able to work on a car now and wanted to move the car 92 Camaro. The last thing that was done a guy came over and pulled all the aftermarket stereo stuff out. When he pulled off the shifter **** with the console he didn't reinstall it right. Now I can't get the car to shift out of park any ideas. Also just finished up installing new front brake calipers and bleed them. Does this affect the shifter with some switch if not enough brake pressure is applied due to air that may be in it still? Have tried 3 times to make sure the air is out now.
Old Jul 7, 2012 | 04:17 PM
kauboy's Avatar
Car: 83 Z28 Crossfire
Re: Shift ****
What does your shift **** look like?
Old Jul 7, 2012 | 07:51 PM
Davejs's Avatar
Re: Shift ****
The shifter has a button on top to shift from park to any other gears. I pulled it off and pressed the staple back in along with rebleeding the brakes and it shifts. I need to pump the brakes to the shifter to shift out of park. I may just bring it over and has a shop bleed the brakes to get out the air and old black fluid.
Old Jul 7, 2012 | 11:50 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Shift ****
Air in your brake lines should/does not affect the shifter.Let alone keep you from shifting out of park.Must be something the installer did/broke reinstalling.
Have you tried shifting it w/ out the **** inplace?
Old Jul 8, 2012 | 11:13 AM
Davejs's Avatar
Re: Shift ****
I have gotten it shifted and moved when I parked it the shifter seems sticky.
Old Jul 8, 2012 | 12:00 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Re: Shift ****
Maybe your not pressing the button all the way down.
Old Jul 8, 2012 | 01:23 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Re: Shift ****
Or the guy didn't push the **** all the way down
Night rider327
Feb 25, 2016 09:50 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
racereese
Oct 3, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
