Good place to run wires from engine bay to passanger compartment?
Car: 1984 Z28 h.o and 1991 RS
Engine: 305 h.o in the z28 & 350-RS
Transmission: t5 & 700r4-RS
Axle/Gears: 7.5 10 bolt posi 3.73 & 4.10 RS
Before I start tearing up the interior looking for a good place to run some wires to my dash where have people run them in the past? This is my first nice car so I don't want to just drill a hole in the firewall and stuff a grommet in there.
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Re: Good place to run wires from engine bay to passanger compartment?
I found a hole big enough to run 4 gauge wire (on driver's side) and then on the passenger side, where the antenna runs out too... I have a 91, you have an 84, take some of the panels (kicks, under dash) and see, may be some you can use...
Rafael
Rafael
Antenna hole, that's a good one. I was worried I would have to run it next to the wiring harness.
AkDrifted
Aug 17, 2015 07:45 PM
db057
Aug 11, 2015 10:11 PM
