Headliner Replacement Help
Old Jul 31, 2012 | 09:39 PM
adamjj_48's Avatar
Car: 1986 Camaro Z28
Engine: 5.0L V8 305ci
Transmission: 700-R4 Built
Axle/Gears: Stock 2.73
I recently replaced my headliner with an ABS one, and I glued it to the roof. It holds well, except for the very front, right above the windshield. That part hangs down an inch or so, and I was wondering, is there a special type of glue or backing that will hold better? All help is appreciated.
Old Jul 31, 2012 | 09:46 PM
jimmy_pop15's Avatar
Car: 1986 Z28
Transmission: 700R
Axle/Gears: Stock
Re: Headliner Replacement Help
telling us which glue you used to begin with would be helpful.
Old Jul 31, 2012 | 09:48 PM
adamjj_48's Avatar
I used Loctite Premium spray adhesive.
Old Jul 31, 2012 | 09:52 PM
Car: 1986 Z28
Transmission: 700R
Axle/Gears: Stock
did it come out in a paint type "mist" or squirt out crazy like that silly string from our kid days? That's how to tell whether the spray adhesive is made more for paper and stuff or for upholstery.
Old Jul 31, 2012 | 10:00 PM
adamjj_48's Avatar
It was more like a silly string, the heavy duty stuff.
Old Jul 31, 2012 | 10:15 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
You could add a OH console,that would help 100%.Just out of curiosity,why did you glue it?
Old Jul 31, 2012 | 10:17 PM
adamjj_48's Avatar
Because it was not a tight enough fit and I didn't want it moving around while driving
Old Jul 31, 2012 | 10:24 PM
mantaguy's Avatar
Engine: 5.0 EFI
I would look into a Overhead Console.You could use Velcro strips also,that would be better than glue,this way you could remove it if needed.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
diana227vegas
Jul 8, 2016 12:27 AM
Golfvette
Aug 24, 2015 06:35 PM
TheJoeY88
Aug 13, 2015 06:51 PM
