Heat not properly working
Old Aug 28, 2012 | 10:12 AM
ChrisC's Avatar
Car: 1983 Z28/2000 ZR2
Engine: CFI to carbed 305/ 4.3
Transmission: Built 700r4/4L60e
Axle/Gears: 3:23/3:73
Hi guys, I have an 83 z28 that is a factory non AC car. I have the 3 selectors: vent-heat-defrost. On all 3 of these, the 3 speeds work fine and I can hear the change. However, on the heat setting, the air is being redirected to the defrost vents and no air is coming through the heater vents. Any thoughts? Vacuum issue? Thanks!
Old Aug 30, 2012 | 09:57 AM
ChrisC's Avatar
Re: Heat not properly working
I pulled the unit forward to check for a vacuum leak at the switch but I dont see anything resembling a switch with vacuum lines or anything of the sort going to it...
Vintageracer
Jan 10, 2020 05:33 PM
mustangman65_79
Sep 1, 2015 03:51 PM
TheExaminer
Aug 26, 2015 04:59 PM
kyle5647
Aug 15, 2015 11:56 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
