camaro/firebird dash
Old Aug 29, 2012 | 10:38 AM
ericamaro69's Avatar
Car: 67 z,69 z, 70 z,74,83 z,89 z,94, 99
hello, does anyone know if the inner dash on camaro and firebird are interchangable. i have a firebird with no dash and a ton of camaro parts cars. wonder if the main dash is interchangable. thanks
Old Aug 29, 2012 | 12:30 PM
tylercamaro's Avatar
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
Re: camaro/firebird dash
they should. only one way to find out
Old Aug 29, 2012 | 01:06 PM
AmorgetRS's Avatar
I'd be willing to bet they aren't, the gauges aren't even close to the same shape.
Old Aug 29, 2012 | 01:21 PM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
Others have swapped the whole entire dash (with wiring) completely out and have made it work. (Firebird into Camaro so the reverse would be possible) Some have said there are some minor differences in how earlier cars and later cars dashes actually bolted up but they have been made to work.
Old Aug 29, 2012 | 03:03 PM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
i have pictures of how the mountings are different. my 85 has a stud on the top mount and my 92 is flat mounted with a keeper. to switch older into new you trim the stud mounted area with a dremel then dill a hole from the top so you can get a bolt to thread in
i think i have pics if you need reference
Old Aug 30, 2012 | 12:09 AM
Zipacna's Avatar
Car: 1988 Camaro IROC T-Top
Engine: 350ci TPI
Transmission: TH-350
Axle/Gears: 4.11 Posi
I have a Camaro with a Firebird dash. It uses the Camaro HVAC box that mounts to the fire wall. The upper mounts in the car were cut off and the lower ones were replaced to meet the new dash.
I have a picture here before I had the correct shift plate/console lid and the map pouch thingy on the passenger side.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
86IROC112
Nov 7, 2015 06:50 AM
Fanatic1074
Oct 2, 2015 03:47 PM
lewandom
Oct 1, 2015 08:15 AM
Eric-86sc
Sep 28, 2015 11:37 AM
