determining original carpet color
Hey all I have a 90 iroc z and a mouse got inside.....needless to say it might be easier to just replace the carpet but im unsure of what the exact color is called.....It looks silver.....
Is there anyway to tell by numbers somewhere what the color was or what colors came thru this year?
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: determining original carpet color
Check your RPO codes,most likely it's a shade of Gray.
I looked thru the codes but have not conclusivly identified the color....I did request samples from stockinteriours.com
AC3
AG9
AG3
AM9
AR9
AU3
A31
A90
B18
B2L
B34
B35
B84
C60
DC4
DE1
DG7
D34
D42
D5X
D8F
D80
D88
E5Z
E9Z
FE2
GU5
G80
G92
IP2
J65
KC4
K34
K68
L98
MD8
MXO
NA5
NP5
N10
N64
N96
QLC
T93
T96
UB3
UM6
UQ1
U79
VAN
V73
WW4
W62
Z28
1AZ
1SD
15P
19Q
41U
6ZW
7ZW
8NL
81A
821
822
829
9NL
1G1FP2380LL126888 1FP87
AC3
AG9
AG3
AM9
AR9
AU3
A31
A90
B18
B2L
B34
B35
B84
C60
DC4
DE1
DG7
D34
D42
D5X
D8F
D80
D88
E5Z
E9Z
FE2
GU5
G80
G92
IP2
J65
KC4
K34
K68
L98
MD8
MXO
NA5
NP5
N10
N64
N96
QLC
T93
T96
UB3
UM6
UQ1
U79
VAN
V73
WW4
W62
Z28
1AZ
1SD
15P
19Q
41U
6ZW
7ZW
8NL
81A
821
822
829
9NL
Engine: 5.0 EFI
Well your 821-822 is your trims and they are shades of gray. usually the carpet is the same color as the seat trim.
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Replacement carpets are not 100% identical to stock no matter what the seller tells you. There's only one major manufacturer of aftermarket carpet (ACC), and their materials & inks are different than stock. They have multiple colors that are very close to your stock gray, but which is "best" can be subjective. Often the color that is closest to the original carpet isn't what actually matches the rest of the interior the best, due to variations in all of the other materials. Find a seller that is willing to send you a few samples so that you can choose for yourself. That's the best way to assure that you get exactly what you want.
Get the samples directly from ACC. The dealers send tiny little swatches. ACC will send you the biggest swatches. You can still buy from who you want, but their samples are bigger.
LT1Formula
Aug 20, 2015 09:36 PM
