Carpet install
Old Sep 23, 2012 | 05:56 PM
1fastrock's Avatar
Car: 89 Camaro IROC
Engine: 383 Stroker
Transmission: turbo 400
Carpet install
I'm looking to put new carpet in my car and was wondering if anyone else has used regular carpet by the yard whether its house carpeting or something like that. I'm really not worried about the sound deadening or anything like that since the car rarely sees anything but the track. Just kind of wondering if it is do able with the shape of the floor.
Steve
Old Sep 23, 2012 | 06:28 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: Carpet install
I don't think it would work without having wrinkles and stuff everywhere. Our cars have a lot of contours inside from the passenger floor board, transmission tunnel and even the back seat are elevated. You might be able to make it work if you were good at seaming it together.
Hawks carries replacements on their website. I've never used them but looks like it ranges from $160 (cargo), $175 (cabin floor), or $260 (complete set).
Old Sep 23, 2012 | 06:38 PM
88redIROC-Z's Avatar
Re: Carpet install
yep your dead on with the prices! here is a link to the site.http://www.hawksthirdgenparts.com/ca...terior/Carpet/
i would suggest using that rather than trying to install cheaper carpet. carpet advertised at hawks is moulded specifically to the shape of your car, and would be much easier to install, and last longer than regular house carpet anyway.
Old Oct 3, 2012 | 12:00 AM
cowansauto's Avatar
Re: Carpet install
Other than being able to see all of the floor pans, you could just use a roll on bed liner kit sold in the auto parts stores. I guess as long as your racing it only then it doesn't really matter.
I still think a factory molded carpet set would look best!
Another tip....If you happened to find a decent carpet set, you can take black spray paint and spray the carpet and then with disposable gloves, run your fingers throughout the fabric to saturate and spread out the paint. Once it dries repeat the process without spraying it again to loosen up the fibers to look like new! Used car lots do this regularly!
Old Oct 3, 2012 | 12:41 AM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
Re: Carpet install
^ or you could re dye one...
Vintageracer
Jan 10, 2020 05:33 PM
lee01
Apr 9, 2016 01:56 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
MORREALE5
Sep 13, 2015 09:16 PM
