Custom dashes
Car: 85 sport coupe
Engine: 355 sbc
Axle/Gears: soon 4th gen 3.23 w/ Posi
Custom dashes
I'm looking at learning how to use bondo and figured I'd go to a salvage yard to pull one out of a camaro there. then hopefully use it to swap out for my crappy cracked one. I wanted to see if any one else has piddled in this area and has anything custom. I've seen one thread a while back where one of the members had done this but didnt knpw if anyone else has and had any tips or pics.
So post 'em if you got 'em
Car: I have a 91 Camaro RS
Engine: 383 stroker
Transmission: Stock automatic 700r4
Axle/Gears: I have 3.73 Gears with a Eaton posi
Re: Custom dashes
I fiber glassed and did a custom paint job on my dash pad look up my thread "anyone done this or seen it done"
Car: 85 sport coupe
Engine: 355 sbc
Re: Custom dashes
Yea, that's the one I mentioned that I saw. It's awesome. I just do not know much about all the materials, what to do, and how to use them.
Car: 1987 trans am GTA ws6 package
Engine: tuned port injection 305 5.0
Transmission: t5 5speed manual
Axle/Gears: 3.08 i think
Re: Custom dashes
Do you think you can give me step by step directions on how to fix the dash I sanded it down, and wondered if next I apply the epoxy In the cracks now!? Thanks
Engine: 383 stroker
Re: Custom dashes
Well if you are going the fiberglass route I would sand it down well to where it is rough to the touch, spread a thin layer of resin, then apply fiberglass cloth, more resin spread evenly with bush, make sure the cloth is saturated completely, (also be sure do do this before resin hardens....then you can start the sanding process from there or you can use a layer of bondo such as I did ..and then you have to sand, sand, sand until you are satisfied with how it looks/feels...then you can paint, either with truck bed liner, auto paint etc.
Re: Custom dashes
Oh k cuz I was planning on fixing the cracks and applying a thin layer of foam over and then put vinyl leather over it? What d u think?
Engine: 383 stroker
Re: Custom dashes
It can work there are other guys on the forum that have done similar projects with great results
