speedodometer help
Old Oct 13, 2012 | 03:54 PM
conleyh2006's Avatar
Car: 1992 camaro rs
Engine: 305 v8 tbi
speedodometer help
hello everyone i have a 1992 305 v8 camaro and i can not get the speedodometer to work i have checked all the wiring and checked the sensor in the transmission i am not sure how to get the actual speedo out of the dash yet. if anyone can help me it will be greatly appreciated thanks
Old Oct 22, 2012 | 07:25 PM
Car: 1992 camaro rs
Engine: 305 v8 tbi
Re: speedodometer help
bump any help would be appreciated
Old Oct 23, 2012 | 07:23 PM
ImBrandon's Avatar
Car: 1991 Pontiac Trans Am
Axle/Gears: 3:42
Check to see if you're connection at speedo sensor the end of the transmission is getting any power with a test light or multimeter.
Old Oct 25, 2012 | 08:27 PM
thmpsn70's Avatar
Car: 1991 Z28, 1980 chevy monza
Engine: 305 tpi in the camaro 3.8 in the mo
Transmission: auto
Axle/Gears: 273 posi
does the tach work, how about the other guages, if not first try the fuse, have you had it out recently? did you get it seated back in its spot with the connector in the dashboard,
Old Oct 25, 2012 | 08:48 PM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
To remove the speedometer for examination, read this thread:
https://www.thirdgen.org/forums/faq-...-fix-pics.html
Also, I suggest that instead of leaving your profile almost completely anonymous, you take a minute to provide others with some info. While it's not necessary to give a bio, your interests, or your exact location, at the very least, you should display your car's year, model and engine size & type.
To do so, click on your user name and in the 'about me' section, click on the pencil icon and please fill in the information that will result in you getting better and quicker responses to your questions.
Old Oct 28, 2012 | 11:39 AM
Car: 1992 camaro rs
Engine: 305 v8 tbi
yes the car is drivable all guages work except the speedo. The sensor at the transmission is putting out voltage and i am getting voltage to the sensor at the transmission through the wires. I havent taken any of the dash apart yet. And i updated my profile
