Door panel/upper trim
Car: 1986 Camaro IROC-Z
Engine: 350 swap
Transmission: manual
How can I remove the "washers" (Or look like a washer)on the upper door trim and that hold the door panel?
Thanks!
Thanks!
Car: 89 Iroc Convertible
Re: Door panel/upper trim
I use a needle nose pliers and they are a pain in the you know what to get off
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
No, they just unscrew, just not well and the nuts are on plastic studs which tend to break. As said, pain in the a
1Aauto
Sponsored Vendors
24
Mar 27, 2018 11:59 AM
IROCZDAVE (88-L98)
Sep 17, 2015 07:43 AM
