Where to find this obscure part for the back of the a/c selector panel???
Old Oct 15, 2012 | 07:31 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
I need this part if anyone knows where to find it. If this part is defective, you lose control over where the air comes into the cabin of the car, in my case everything is blowing through the defrost vents no matter what the selection is on.
The Four Seasons part number is 36692 and the Delco part number is 15-71548. I've looked all over the internet and local parts stores and it's not available.
It looks something like this (stock photo from amazon.com)
And it bolts to these two screw holes where I'm pointing.
Old Oct 15, 2012 | 07:57 PM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
Re: Where to find this obscure part for the back of the a/c selector panel???
This shouldn't be hard to locate; as long as you don't mind used. Try Don (member 89irocz355). He's always parting cars, ships quickly and coincidentally, he just listed a 92 here: https://www.thirdgen.org/forums/engi...92-camaro.html
Old Oct 15, 2012 | 08:06 PM
BlueZee28's Avatar
I dont mind used as long as its not defective.
Old Oct 15, 2012 | 08:09 PM
alan91z28's Avatar
COTM Editor
Car: 91/89/85/82 Z28s, 88 TA, 88/88 SC
Engine: SBC and LS variations
Have you called Bruce at Hawks? I am sure he could get you one off one of his part out cars
Old Oct 15, 2012 | 08:37 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
You might consider a fix:
https://www.thirdgen.org/forums/inte...anent-fix.html
JamesC
Old Oct 16, 2012 | 10:12 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Also check www.thirdgenranch.com
Send Denny a e-mail and ask about a used one.
I don't see any listed there so e-mail is best.
Old Oct 16, 2012 | 05:34 PM
82tarecaro's Avatar
You could buy this at a parts place for as long as I can remember. It must have been recently discontinued. I would try the fix JamesC refers to. It seems like a permanent solution to a common problem.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
1nastygta
Aug 8, 2015 07:38 PM
