89 Firebird Formula Center Console Concern
Old Oct 16, 2012 | 04:03 PM
ZenShaman's Avatar
Car: 89 Firebird Formula 305
Engine: v8 TBI 305 LB9
Transmission: Automatic
Hi I got a 89 Formula 305 and the center console automatic shifter doesnt light up, Id like to know what needs to be replaced BEFORE i tear it all up if possible so can anyone help me? Its the part that says "1,2 D, OD, N" etc
The "2" is lit up nothing else.
Also, what part do I replace if my ash tray cover doesn't slide properly? will just a new lid do or is it the tray or both?
I have no idea as I haven't seen it completed since my car doesn't have it
Old Oct 16, 2012 | 05:02 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: 89 Firebird Formula Center Console Concern
If I remember right it's just a tiny bulb and a slider type that moves down the channel. Pull the U clip from the front of the shifter ****. Remove the screws in the console and lift it up. You need to be careful with the ash tray as it has a lighter and the glove box should have a light in it too. Make sure you don't crack your radio trim removing the console since the plate curls under it.
Old Oct 16, 2012 | 06:52 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Their is only one bulb,it sounds like your bulb socket slipped out of the holder and is only illuminating in the one area.
Old Oct 17, 2012 | 12:49 AM
ZenShaman's Avatar
alright ima take a crack at it tmrw morning and let you guys know
does anyone know about the ash tray?
Old Oct 17, 2012 | 12:59 AM
mantaguy's Avatar
Engine: 5.0 EFI
From what I here,their a little tricky trying to install the ashtray lid,you might want to switch the whole console plate.
Old Oct 17, 2012 | 02:46 AM
Engine: 383 SBC
Take it apart maybe and check maybe the springs are out of alignment. Formula plates go for $50 to $90 on ebay so I would look as a replacement as a last resort.
1992 Trans Am
May 10, 2023 07:19 PM
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
colton_carlson
Mar 8, 2019 12:21 PM
theshackle
Mar 5, 2017 06:37 PM
Firebird sweden
Aug 16, 2015 05:02 PM
