Identify this part please
Old Oct 14, 2012 | 12:38 AM
jackhammer's Avatar
Car: 1987 Camaro RS
Engine: V6
Transmission: Automatic
I am working on my 87 RS. When I removed my steering column, this 3 inch long plastic piece with an O ring and a spring popped out from somewhere under the dash. When I pulled the replacement column at pick a part the same part popped out. Someone please identify this for me and give me instructions for replacing it. I'm not sure where it goes or which direction the spring goes either. I am replacing my column and need to reinstall the replacement asap. Please see the attached photos.
Thank you for your help.
Attached Thumbnails Identify this part please-pict0039.jpg   Identify this part please-pict0040.jpg
Old Oct 14, 2012 | 03:02 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Identify this part please
My guess is that it's the spring and guide for the tilt mechanism.
Old Oct 14, 2012 | 12:23 PM
jackhammer's Avatar
Car: 1987 Camaro RS
Engine: V6
It is not the spring for the tilt if you are talking about the one located inside the column under the steering wheel lock plate. All of those parts are still intact. My guess is that it came from somewhere near the ignition which is half way down the column. Any other ideas? I'm sure someone has seen this part before. And once again, thanks.
Old Oct 14, 2012 | 12:45 PM
Tehsocks's Avatar
Car: 85 Camaro Z28
Engine: 6.0L LS
Transmission: T56 Magnum
I think that part of the brake light switch....
Old Oct 14, 2012 | 01:59 PM
jackhammer's Avatar
Car: 1987 Camaro RS
Engine: V6
YES! You are right. Now that it is daylight and I know what I'm looking for I could spot it. Thank you very much. Now off to the store to get a replacement.
Old Oct 15, 2012 | 09:15 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
No, that's not the brake light switch. That's the rod for the cruise control brake release switch (vacuum side). I hated it when that stinking thing would come apart for almost no reason.
Old Oct 15, 2012 | 09:52 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
Those pictures are so big that once I zoom out far enough to see them I can't read the text because it's so small it looks like a straight line.
Old Oct 17, 2012 | 03:50 AM
jackhammer's Avatar
Car: 1987 Camaro RS
Engine: V6
YES you are actually the one who is right. It's right next to the light switch. I just found it right now at autozone. Thank you all for you help.
LT1Formula
20
Nov 14, 2015 12:02 AM
Linson
Aug 21, 2015 02:12 PM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
