Seat cushion interchangible L to R
Old Nov 15, 2012 | 05:51 PM
BADNBLK's Avatar
COTM Editor
I'm getting ready to replace the seat covers in my convertible, and the drivers seat has some pretty severe foam damaged in the inner welting area. I'm sure I could stuff it, but I have a good passenger side bottom from my parts car...
Question can the front seat bottom be exchanged right to left? Obviously the seat frame and covers will be off, so just the foam.
Here is what I'm working with...
Old Nov 16, 2012 | 10:53 AM
SolarGoldRaptor's Avatar
Car: 1984 Pontiac Firebird Trans Am
Engine: V8 5.0L HO (L69)
Transmission: B&W T5
Axle/Gears: 3.73 limited slip
Re: Seat cushion interchangible L to R
Yes the foams are identical, the cover should be symmetrical as well.
Old Nov 16, 2012 | 11:00 AM
BADNBLK's Avatar
COTM Editor
Thank you. I was unsure from when I recovered the seat bottoms on the 91. Thanks again!
Old Nov 17, 2012 | 05:19 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
I swapped both the foam base and back, even the cloth covering from a passenger-side to drivers-side. I did have to use a iron patch inside to cover the hole for the seat release.
Lon
Old Nov 17, 2012 | 05:50 PM
BADNBLK's Avatar
COTM Editor
Lon
Thanks Lon!
Old Nov 19, 2012 | 05:16 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
I replaced my drivers seat bottom with a passenger one from a junk yard, although I think the 20 year old foam is collapsing on that one as well (only 185 lbs, in case you were wondering!), so it might be time to buy new foam. Classic sells it I believe...
MrPackstin
Oct 25, 2017 08:09 PM
GageBrand
Oct 22, 2015 02:30 PM
Briandrex
Oct 5, 2015 06:20 AM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
kitt23
Sep 26, 2015 07:48 PM
