Brighten Up the Interior
Old Dec 2, 2012 | 11:26 PM
Mr. McGuire's Avatar
Car: 91 Camaro Z28
Engine: 305 V8 (5.0L) TPI
Ok, so alot of people on here can agree that maybe the interior of the third gens are very dim lit and few LEDs would brighten it up. After all we spend more time in the car than outside it.
What I had in mind is brighten the floor shifter lights (automatic models) and the dome light. I bought a LED bulb from Pepboys and hoped that all my problems were over. Well, needless to say the light was bright but this weird cover thing was blocking the lights to be seen well through the letters and numbers for the floor shifter. What can I do to brighten that up?
Same goes for the dome light. I want to be able to keep the cover over the light bulb in the dome light to keep the insides clean and dust free, at the same time have a well lit interior.
That 80s plastic that gives off that dim yellow tinted light is an eye sore for such beautiful cars.
So the questions are: how can I do away with the horrible looking lighting and have a more modern LED, bright, well lit interior?
Old Dec 3, 2012 | 02:33 PM
system155's Avatar
Car: 89 camaro iroc, 89 camaro rs
Engine: 350-iroc / 305 rs
Transmission: 700r4 / t5
Re: Brighten Up the Interior
will if u dont have t tops u can try to put a 98-04 overhead console in but there will be some mods ur going to have to do to make it look right
Old Dec 3, 2012 | 06:22 PM
85FBTranam's Avatar
Car: 1985 Pontiac Trans Am
Transmission: BW T5, Hurst Short Throw Shifter
Axle/Gears: 3.70 Posi
I didn't like how dim the interior was either. Replaced dome light with an SMD LED panel, installed a rear view mirror with lights (replaced with SMD LED's), added two SMD LED's to the footwells. Huge difference. Most of the bases are 168/194 and are plug and play.
Old Dec 3, 2012 | 08:54 PM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
The dome bulb is called a festoon bulb. You can get all the LED bulbs you want at superbrightleds.com. Great place.
RyanJB
May 7, 2016 06:23 PM
codeysabatini
Sep 20, 2015 11:36 AM
MORREALE5
Sep 13, 2015 09:01 PM
sylentnite
Sep 9, 2015 02:55 PM
