Help with broken trim panel
My door panels were in very bad shape i removed the cleaned them and painted them black with fabric vinyl paint now they look awesome but theres an issue the trim panel that is attached via metal speed nuts that are screwed onto plastic nibs molded to the inside of the plastic trim plates are broken all of them! the trim panel is in good condition except for that what can i do to fix this? here are the pics so you can see.
Car: 1990 Camaro RS
Engine: L31
Re: Help with broken trim panel
What I would try is grind it flat and epoxy some bolts to the back. You could then use nuts and washers to hold it to your panel.
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
i have used a hot glue gun with good results on the same problem . good luck ...
wigmobile
Feb 26, 2025 02:56 PM
1Aauto
Sponsored Vendors
24
Mar 27, 2018 11:59 AM
1Aauto
Sponsored Vendors
Nov 9, 2015 02:25 PM
