got a ? about power windows vs crank windows
Old Dec 18, 2012 | 06:38 PM
92camarorv6's Avatar
Car: 92 camaro rs
Engine: 3.4v6 sc
Axle/Gears: 9 bolt 3.73s
hey tgo i was talking to a buddy to day hes a 4 gen guy he said the power windows are lighter then crank up window's dose that fall the the same for 3 gens ???
Old Dec 19, 2012 | 06:40 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Re: got a ? about power windows vs crank windows
I would be surprised if it was true for 4th gens , but definitely not true for third gens. Our electric motors are pretty big. However the difference is not as much as you might think since the regulator gear and arms are really heavy by themselves. I can't remember what the difference was when I measured, but it wasn't enough to make me want to switch to manual regulators so I chucked them.
Old Dec 19, 2012 | 10:52 AM
Car: 92 camaro rs
Engine: 3.4v6 sc
really the motor in the door from the 91 i got it from is tinny
Old Dec 19, 2012 | 11:02 AM
stealtht/a's Avatar
Well I guess it depends what you compare it to, all third gen motors are the same size. The motors on my VWs are much smaller, but they have much smaller windows and a wire and plastic regulator (not the most durable setup). My older jeeps have giant motors that drive a cable. They weigh a ton. Either way, My scale isn't accurate to small increments, so I weighed the complete regulators in pairs and the difference was less than a pound.
Old Dec 19, 2012 | 02:25 PM
Car: 92 camaro rs
Engine: 3.4v6 sc
well i would like to know so i can pick one i have a hole parts car i can get the power widnow stuff out of my rs is crank windows and its kinda getting old
Old Dec 20, 2012 | 06:26 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
If you're looking to save weight, don't bother with the power windows. Both manual regulators together might weigh about as much as one power regulator.
And then you have the additional wiring...
Old Dec 21, 2012 | 04:32 AM
stealtht/a's Avatar
Both regulators together? I have to disagree. There's isnt that much difference. They both are basically the same regulator with the huge metal struts and big gear , the only difference is the motor on power and crank stud on the manual, it leaves very little difference in weight. The wiring can't weigh all that much either. Power windows are well worth the minimal weight.
Old Dec 21, 2012 | 06:18 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Well, I just did the conversion on mine about 6 months ago. And I can tell you for a fact that one manual regulator weighs about as much as one motor EXCLUDING the rest of the power regulator (including the big balance spring). And the entire harness is basically the same as adding a 3rd manual regulator (in weight). Of course, that includes the power lock harness. There is a thread detailing the weight difference between manual and power windows. And that doesn't count the crank handles.
The regulators are NOT basically the same. The power regulators have the balance spring. The manual regulators have more of a backframe for the manual gear.
Again, if you're interested in weight savings, keep the manual regulators. If you want convenience, put the power regulators and harness in. But it will cost a couple pounds in weight.
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
sailtexas186548
Aug 24, 2015 10:11 PM
stalkier
Aug 21, 2015 01:54 AM
Dialed_In
Aug 20, 2015 01:45 PM
