only my defrosters work. not my other vents
90 camaro rs. I turn on my heater and only my defroster vent blows. Is there another blower motor somewhere. I have a really nice interior and I don't wanna destroy it. So I am asking for some help and some insight on this. Please and thank you.
Car: 1992 Camaro RS
Engine: 1978 L82 355
Re: only my defrosters work. not my other vents
Somewhere either inside the dash or in the engine bay, there is more than likely a vacuum line for the blower controls unplugged or broken. Check around on your intake for a disconnected/broken vacuum line coming from the passenger side firewall, and if you can't find the problem you can do what I've done. I jammed the vent doors to stay open so all vents are going at once. It will get me the through the winter for now.
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Check your ported vacuum lines,their behind the heater control unit I/P,listen for hissing sound,if so,you have a vacuum leak.
Here's a link,it explains.https://www.thirdgen.org/forums/cool...ac-heater.html
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
If it's the switch, a part number is provide in the link above. You might also consider a fix:
https://www.thirdgen.org/forums/inte...anent-fix.html
JamesC
JamesC
@ Jesse shredd. What vent did u jam open? And where is it located? I'm going to do that until I can fix the problem the right way. And also my car came factory with no ac controls or options. Is that common for a 90 camaro rs? No ac at all. Thank you for our help
Pac J
May 17, 2020 10:44 AM
