Help with interior lights
Old Jan 8, 2013 | 10:16 PM
Gumby40's Avatar
Car: 1986 Trans Am
Transmission: A/T
Axle/Gears: No Clue
Ok guys, my sons has a 86' Trans Am that i noticed the shift indicator light doesnt work along with the power door lock, window switches and headlight switch. His Grandfather bought this car new and it has been sitting in his garage since 1999.
Old Jan 8, 2013 | 10:18 PM
Gumby40's Avatar
Car: 1986 Trans Am
Transmission: A/T
Axle/Gears: No Clue
Re: Help with interior lights
Oh and I should add none of the fuses are blown........here it is when i sprayed 12 years of dust off it.
Old Jan 9, 2013 | 12:50 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Sounds like you have a bad Ground,make sure the ground wire next to the fuse panel is clean and tight.If you look up to the left of the fuse panel you will see the ground wire,it;s grounded near the hood release.Nice looking 86 you got their.
BRoss99
Aug 10, 2025 05:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
The_Phoenix
Feb 4, 2016 07:10 AM
Omega
Aug 10, 2015 12:46 PM
