Blower motor went out?
Old Jan 14, 2013 | 12:09 PM
19GTA92's Avatar
Car: 1992 Pontiac Trans Am GTA
Transmission: 5 speed
I'm driving back to school last night and noticed that my windows started fogging up, but the defroster was still on. So I messed with the controls and it still would only push out a little air on no matter what option. I turned the speed dial and it didn't do anything? So would that be the blower motor? Just wanna make sure before I go diving in head first.
Old Jan 14, 2013 | 01:10 PM
rickwise's Avatar
Car: 1986 camaro
Transmission: a.t.
Re: Blower motor went out?
Check fuse first. Try tapping on motor, should be under hood on passenger firewall. This might get motor to run, if it does, motor is bad. There should be a resistor in the heater box by the motor, it could be bad.
Old Jan 16, 2013 | 05:29 PM
19GTA92's Avatar
Okay, I checked the fuse and it was fine so I went ahead and replaced the blower motor. It works now, but it wont shift off of defrost? At least I have defrost for now in the mornings, but do you have and ideas why it won't switch off defrost?
Old Jan 16, 2013 | 05:51 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Vac leak. Defrost is the default.
JamesC
Old Jan 16, 2013 | 08:21 PM
19GTA92's Avatar
JamesC
Any idea on how to find where its at? Could it be from the cooling line not sealing all the way from the new blower?
Old Jan 17, 2013 | 07:13 AM
rickwise's Avatar
Car: 1986 camaro
Transmission: a.t.
Listen for hissing from behind HVAC switch in dash. This would indicate a leak.
Maybe just the vac harness plug is loose, or leaking from switch.
Frozer!!!
Jan 19, 2024 04:55 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
zayne0
Aug 24, 2015 07:22 PM
mhatfield 14
Aug 15, 2015 10:47 AM
Street Lethal
Aug 13, 2015 08:28 PM
