Console Clock Second Hand Question
Old Feb 14, 2013 | 08:50 PM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
To my surprise I actually found a Camaro console clock at the junkyard. I have it in pieces repairing it, restoring it cosmetically and resurfacing the lens.
I had a question about the second hand for anyone who knows about these clocks. Does it tick or sweep? When I took the clock apart the second hand was bowed upwards like a banana (Unknown to me this was because of sun damage). I figured it was just bent and tried to bend it back straight but it shattered into about 5 different pieces.
I am debating fabricating a second hand for it or running it with just the minute and hour hands.
Old Feb 14, 2013 | 09:15 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Re: Console Clock Second Hand Question
It ticks....second hand moves. It should still run fine with the remaining hands however....
Old Feb 15, 2013 | 10:35 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
I copied this from a post I made in 2005:
You're in luck. I did some research a while back and found the only source for parts and service for these clocks. Originally made by Wesclox, the entire inventory of parts was purchased by "the Clock Doc" (800)256-5362. Bill is the contact. He may be able to repair yours or sell you a reconditioned one. He also can mill the face of the clock so it looks like new again.
Good luck,
Lon
Old Feb 15, 2013 | 05:53 PM
Confuzed1's Avatar
Car: 83Z28 HO
Good luck,
Lon
That's awesome if the guy is still around! Mine doesn't keep the best time...I'll lose about 5 minutes a week.
Old Feb 15, 2013 | 07:47 PM
drjewalton's Avatar
Car: 1956 Chevrolet 210
Engine: Chevy 305 V8
Transmission: TH350
Axle/Gears: Posi 3.42
Meguair's headlight restorer with sanding pad works pretty well to restore and bring clarity back to the face.
A little squirt of WD-40 to the clock mechanisms keeps it running smooth. Just my 2 cents.
Old Feb 15, 2013 | 08:33 PM
Confuzed1's Avatar
Car: 83Z28 HO
I just used plastic polish I picked up. From Autozone...but I bet the headlight restorer works well too!
1992 Trans Am
May 10, 2023 07:19 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Casey Meyers
Mar 2, 2016 10:46 AM
redmaroz
Aug 16, 2015 11:40 PM
TheJoeY88
Aug 13, 2015 06:51 PM
