Console repair
Old Feb 16, 2013 | 07:48 AM
MikeMN's Avatar
Car: 1988 Trans Am GTA and 1979 10th Anv
Console repair
I was wondering if any of you had fixed this issue before, getting the vinyl sides tight against the shifter, if so how did you go about doing this .....?
Old Feb 16, 2013 | 08:22 AM
WolfmanTA's Avatar
Car: 1986 Trans Am
Engine: LB9 TPI V8
Transmission: automatic
Re: Console repair
Here check this out! Mine was the same as your pic. I followed the steps and glued it with clamps. Looks like new now. Trick is to clean the clue off it good first. Check this out Bro..
https://www.thirdgen.org/forums/inte...d-console.html
Old Feb 16, 2013 | 08:35 AM
MikeMN's Avatar
Re: Console repair
Thanks for the link, I think I will try and get most of the foam or glue, what ever it is, off and give it a try.
Old Feb 16, 2013 | 09:24 AM
WolfmanTA's Avatar
Car: 1986 Trans Am
Engine: LB9 TPI V8
Re: Console repair
No Prob Bro! I fixed mine without having to take it out.Just unscrewed the shifter face plate pulled the pin on the shifter ****. Took it off then the shifter plate. Cleaned up the old glue really good and use Epoxy Glue with some small clamps. Left it for a day just to be safe. It's a common problem with the shift consoles. Good luck! Cheers....
Lbibb
May 5, 2016 12:00 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
ndndndnd
Sep 28, 2015 08:00 AM
