rear seatbelts stuck
Old Feb 24, 2013 | 02:04 PM
jdawg1276's Avatar
Car: 1988 camaro
My rear seatbelts are stuck won't go in or out both sides how do I fixed this problem?
Old Feb 24, 2013 | 08:13 PM
jdawg1276's Avatar
Car: 1988 camaro
Re: rear seatbelts stuck
Bump
Old Mar 1, 2013 | 08:10 AM
jdawg1276's Avatar
Car: 1988 camaro
is there no one who can help point me in the right direction
Old Mar 1, 2013 | 03:39 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Sounds like you have some debris or a foreign object jammed in there that's keeping the belts from moving. I assume you've tried yanking on them from different angles to try and get them to work.
IIRC, the seatbelts are sealed and are not serviceable. You might need to look for replacements. Should be relatively easy to find and inexpensive at most JY's, they rarely wear out.
Old Mar 1, 2013 | 03:44 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
DId you stuff fat tires on the rear? May have required some hammering on the inner fenders.
Old Mar 3, 2013 | 04:51 PM
jdawg1276's Avatar
Car: 1988 camaro
Yes I have tried pulling on both of them so there is no inspecting them and thanks for the reply
Old Mar 3, 2013 | 04:53 PM
jdawg1276's Avatar
Car: 1988 camaro
no it has stock tires on it
Old Mar 3, 2013 | 04:54 PM
jdawg1276's Avatar
Car: 1988 camaro
is there a safety device on them it's just weird for both to be stuck in there?
Old Mar 3, 2013 | 04:59 PM
Nonni's Avatar
Car: 86 T/A
Engine: ZZ383
Transmission: TH700R4 Raptor
Axle/Gears: 2,7x -> 3.00 or 3.50
I had the same problem on left side, the reason was that when I was putting the interior back in my car the plastic interor parts locked up the belt. I just had to loosen them up a little and put the seat belt in correct place.
Cameeeero
Sep 18, 2015 04:00 PM
backtothe80s
Sep 5, 2015 12:39 AM
yankeecarman
Convertibles
Aug 23, 2015 07:47 AM
bbernardo94
Aug 19, 2015 05:25 AM
