where are common areas where build sheets are found
Car: 1987 Camaro Z28
Engine: Carbed 355
Transmission: Borg Warner T56
Axle/Gears: 4th gen 10 bolt 3:73 Richmond gears
i have heard they are under a seat, under the carpet, or between the bumper cover and bumper. are these true and are there other areas? i am searching for mine in my 1984. were these areas year specific etc. anyone have answers?
INCLUDE YEARS TOO
INCLUDE YEARS TOO
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Re: where are common areas where build sheets are found
I found one in the truck area under the carpet. I cant believe they would put them under there. So dumb. Throw them under the center console or on top of the hump to the rear of the car
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
well i found mine under the driver side rear seat, under the carpet and insulation. this one was 86.
Car: 87 monte aerocoupe
Engine: 383 HSR w/ novi 2000
Transmission: Built 4l80e circle d converter
Axle/Gears: Currie 9" 3.89 gears
I found some of mine under the drivers front seat. It was between the wire support and the foam of the seat. I have an 83 Z28.
Found one under the carpet on top of the tank hump. That was an 82 Z28. Found another behind the plastic over the rear wheel well on the drivers side. Think that one was an 83. Not all cars have them. It's possible to get one from another car too.
Car: '84 Z28
Engine: '02 LS1
Transmission: '02 T56
Axle/Gears: LS1 10-bolt 3.73 w/Auburn Pro
Mine was under the foam on the driver's seat on an '84 Z28 L69/T5 made in Van Nuys.
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
Under the drivers seat on mine but totally shreded to bits. I wish I could have saved it.
Car: '92 RS heritage convertible
Transmission: auto
I will be looking for mine this spring , I'll start with the drivers seat as that seems like the most popular spot ,
But i have a question , What can the build sheet tell you , That the RPO sticker does not . Sorry if thats a stupid question.
Engine: Carbed 355
im only looking for it because someone ripped my rpo sticker out of my glove box
