Cheap Classic Industries Sound Deadener, any good?
Old Mar 26, 2013 | 06:35 PM
Ashton89iroc's Avatar
Car: 1987 IROC-Z
Engine: Vortec 350 crate #12530282
Transmission: 700-r4 Auto
Hey guys, I'm going to be doing a complete rebuild of my IROC this summer (engine, body, interior and paint..the works) and I was wondering if any of you have bought the cheaper sound deadener that Classic Industries carries?
Here is a link to the stuff i'm talking about...
http://www.classicindustries.com/cam...s/cmd1003.html
I was looking to get some opinions on this product. Just to see if it is any good, what the thickness is, who the bloody manufacturer of this stuff is. Its just a generic off brand, but I figured an off brand wouldnt matter so much with this. Some things you dont want an off brand, but others it doesnt matter...(like cheap cereal, it tastes the same haha.) My plan was to buy 2-3 sheets of this and cover nearly EVERYTHING in my interior with it and then throw some Neoprene foam sheets under the seats, foot area and probably the rear wheel wells. I'm on quite the budget and can't afford Dynamat or others like it, this seems to be the only stuff i've found that I can work with on the price.
tell me what you guys think and feel free to discuss it, thanks!
Old Mar 26, 2013 | 08:38 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Cheap Classic Industries Sound Deadener, any good?
Their offering a 20% discount if you should go with this product.use code MAD13,it's good till April 2nd.That should help a little with your budget
Old Mar 26, 2013 | 08:41 PM
Car: 1987 IROC-Z
well alright! thanks! I'm just afraid that if i end up going with this, that it will just end up being a paper thin waste of money.
Old Mar 27, 2013 | 12:34 AM
Car: 1987 IROC-Z
I've done some reading here, and apparently it takes over 100 square feet to cover the floor, rear hatch area and doors?!? I pulled out a measuring tape just to see how much that really was and HOLY CRAP! unless i did my measuring wrong (i just mocked up a rectangle that is 25 feet long and 4 feet wide) but that looks like WAAAYYYY more then is needed to do the interior...am i right? how much would i actually need just for the floor, doors and hatch area, including inner wheel wells?
Old Mar 27, 2013 | 07:26 PM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
I used rattletrap from this eBay seller. It shipped quickly and was exactly as described. I did the everything but the roof (I have t-tops) and used every last inch of the 100 feet.
Warning: installation SUCKS! I spent about 18 hours trimming and installing. Sure, some would say "it's hidden anyway" but since I was doing a full interior restoration, I needed to keep up the **** mentality!
http://www.ebay.com/itm/100SqFt-Rattle-Trap-No-Logo-Deadener-Super-Stick-Formula-Free-Dynamat-Sample-/121002290776?pt=Car_Audio_Video&hash=item1c2c4c6e58
Old Mar 30, 2013 | 11:32 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
It's going to take you 32 square feet, just to do the doors, covering both skins, plus about 16 for the roof, so there's about 50 without touching the floor!
Old Mar 31, 2013 | 09:18 AM
carlos64030's Avatar
Car: 1991 Trans Am GTA
This thread just made me realize that I will need to buy a lot more Dynamat Xtreme to do my entire interior. I've already purchased one case of 36 ft, but that won't be nearly enough. Looks like I'll have about $500 to $600 wrapped-up in this stuff when all is said and done.
Old Mar 31, 2013 | 09:23 AM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
But if you put padding and carpet on the floor, how will you ever sort out the sources of all the water leaks? Name:  brick.gif
Old Apr 2, 2013 | 12:48 AM
Car: 1987 IROC-Z
I suprisingly dont have any leaks in my interior. My T-tops and doors dont leak at all. But I'm using neoprene foam as a replacement for that crappy stock insulation they have under the carpet, so if i ever do spring a leak somewhere...i can't imagine it will be hard to track it down. Good point though none the less.
Old Apr 9, 2013 | 03:23 PM
Car: 1987 IROC-Z
I didnt notice this was jute padding, not anything like dynamat and similar projects. definately not going to buy it.
Frozer!!!
Jan 19, 2024 04:55 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
db057
Aug 22, 2015 08:17 PM
midias
Aug 22, 2015 01:42 AM
mustangman65_79
Aug 7, 2015 09:55 PM
